- Platform information:
- Hardware: Synology DS918
- OS: DSM 6.2.1-23824 Update 6
- Java Runtime Environment: 8.0.161
- openHAB version: 2.4
- Issue of the topic:
In Paper UI I click on
then nothing happens.
I tried to add my IPhone manually then it can discover it, why can’t it autodiscover it? I assume that the openhab system has not the correct access rights. Has anyone an answer to that? Or is there some setting in the fritz.box which prevents the openhab process to discover items on the local network?
This is how I added the iphone manually:
I copied and pasted the ip from the fritz.box homenetwork page. And I made sure that the IPhone always receives the same ip adress by clicking the checkbox in the fritz.box settings page.
Access Rights for User openhab
- If logs where generated please post these here using code fences:
It only works when manually adding the device why?
