Well, I am trying to follow the documentation. It says “/volume1/public/openHAB2/conf/” If that is incorrect perhaps a change is needed. Would love to make the small effort to the git-repo for it when this is sorted out.
Perhaps I am assuming incorrectly that that the conf/things/ should contain something when paperUI displays three Zwave “things” ?
unless you created the things file yourself, paperui-created things live elsewhere.
off the top of my head /volume1/public/openHAB/userdata/jsondb i think…but its not gonna be particularly readable.
OK, thank you. That explained things a little bit. Tried simplest form of sitemap and it is picked up from /volume/public/openHAB/conf/ , visible in basicUI.
If this is default behaviour when choosing public option when installing, I propose to change the documentation.
Maybe it’s slightly off topic, but if you’re doing a new installation on Synology, I would suggest going with a docker install instead. It is much simpler to sett up because almost all installation steps are contained in the docker image. This gives you a very portable installation.
