Syr / Oceanic Safe T binding
Hey,
I am using a Syr Safe T connect.
Openhab got a binding for Oceanic devices, but not for the Safe T.
The Wibutler supports this device (so there is working solution).
As fas as I understand it is controlled from the wibutler via the Syr cloud and not direct via lan. TCP/IP (via Cloud)
I found this information about it (in German), maybe someone could develop a binding for the Safe T or help me to get it connected via http binding?
https://www.msxfaq.de/sonst/iot/syr_safe-t_connect.htm
https://www.wibutler.com/media/downloads/5d2338e83c96c1271866b54b/wibutler_Leitfaden_-Leckageschutz-_SYR.pdf
Thank you!
Dirk
If you want this, start a bountysource to hopefully attract a developer.
i’m also using the Syr Safe T device and missing the binding for it. Could the binding be added as a new feature on github? I would support it on bountysource.
Lukas
