What version of Java are you running on the rPi3? (try "sudo java -version")
and which release of OH2 have you installed (with which method: manual or apt?)
pi@RaspberryPi3:~ $ java version "1.8.0_111"
java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
pi@RaspberryPi3:~ $
meanwhile I tried several OH versions: OH2 beta release and snapshot release (apt installation) and also the most recent OH1 revision.
All of them give the same failure
Did you ever get any release of openHAB to start up correctly in the past?
If yes: one possible root-cause could be SD Card filesystem corruption
If no: something may be wrong with your Java installation…
Another possibility is that you need to clean your old openHAB installation folders and then re-install (with apt) a new release (go for RC1)
That’s it.
I removed the installation using apt-get purge and found finally still some openhab files left (e.g. /opt/openhab folder).
I removed them manually and installed OH2 again.
Now it works
Thanks for your help
