Some help required please to understand why three services that have been installed are being killed on/after booting the system.
Frontail - installed via openhabian-config
openhabian@openhabian:~ $ journalctl -u frontail -b
-- Logs begin at Thu 2021-02-18 15:06:13 AWST, end at Fri 2021-02-19 12:25:01 AWST. --
Feb 19 08:47:12 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
Feb 19 08:47:13 openhabian systemd[1]: Stopping Frontail openHAB instance, reachable at http://openhabian:9001...
Feb 19 08:47:13 openhabian systemd[1]: frontail.service: Main process exited, code=killed, status=15/TERM
Feb 19 08:47:13 openhabian systemd[1]: frontail.service: Succeeded.
Feb 19 08:47:13 openhabian systemd[1]: Stopped Frontail openHAB instance, reachable at http://openhabian:9001.
Here’s the file: /etc/systemd/system/frontail.service
[Unit]
Description=Frontail openHAB instance, reachable at http://%H:9001
Documentation=https://github.com/mthenw/frontail
After=openhab.service
PartOf=openhab.service
[Service]
Type=simple
ExecStart=/usr/lib/node_modules/frontail/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab_dark.json -t openhab_dark -l 2000 -n 200 /var/log/openhab/openhab.log /var/log/openhab/events.log
Restart=always
User=frontail
Group=openhab
Environment=PATH=/usr/bin/
Environment=NODE_ENV=production
WorkingDirectory=/usr/bin/
[Install]
WantedBy=multi-user.target
Same thing is occuring for Influxdb and Grafana (both installed via apt-get, manually configured).
Feb 19 08:48:12 openhabian systemd[1]: influxdb.service: Main process exited, code=killed, status=13/PIPE
Feb 19 08:54:02 openhabian systemd[1]: grafana-server.service: Main process exited, code=killed, status=13/PIPE
All three services operate normally if I start them with sudo systemctl start servicename.service
- Platform information:
- Hardware: RaspberryPI 4 2G
- OS: Linux openhabian 5.4.83-v7l+ #1379
- Java Runtime Environment: Zulu11.43+88-CA (build 11.0.9+11-LTS)
- openHAB version: 3.0
