Systeminfo binding installing error
I´m trying to install the Systeminfo binding within the UI, but only “hourglass” appears when pressing on “Install”.
Logfile is saying:
> 	58930	2023-03-14 08:34:38.507 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-systeminfo': Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-transformation-map; type=karaf.feature; version="[3.3.0.SNAPSHOT,3.3.0.SNAPSHOT]"; filter:="(&(osgi.identity=openhab-transformation-map)(type=karaf.feature)(version>=3.3.0.SNAPSHOT)(version<=3.3.0.SNAPSHOT))" [caused by: Unable to resolve openhab-transformation-map/3.3.0.SNAPSHOT: missing requirement [openhab-transformation-map/3.3.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.transform.map; type=osgi.bundle; version="[3.3.0.202206260339,3.3.0.202206260339]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.transform.map/3.3.0.202206260339: missing requirement [org.openhab.transform.map/3.3.0.202206260339] osgi.service; filter:="(objectClass=org.openhab.core.transform.TransformationConfigurationRegistry)"; effective:=active]]
So I assume the Transformation Map Service is missing?
thats curious, as it´s installed and active.
Running OH3.3.0 on Win10
Maybe try installing an actual 3.3.0 release?
Based on your screenshot you are running a 3.3.0-SNAPSHOT version created on 2022-01-20 while 3.3.0 was released on 2022-06-27. So it’s missing almost all development work done on OH 3.3.0 and it’s more like OH 3.2.0. :wink:
looks this was the reason. Just updated to 3.4.2 and the binding seems to be installed successfully now. Thanks!
