Since a few weeks the binding systeminfo stops working.
It only works for one measurement once I install the binding and after that it stays silence without any errors and no log…
The binding worked great for over half an year but somehow now it behaves strangely
I use the default configuration parameter and for the values that I need they are set to medium.
But I found the proplem as soon as I set the interval_high and interval_medium to the same time interval it does not work.
I now set it as follow and now its working again!
I can’t see any obvious issues with this in the binding code, but it might be a concurrency issue in the OSHI library. If you want to investigate, set the binding to DEBUG level logging and see what it outputs.
hmm when I save the things file with high and medium priority set to the same value I get no log output at all.
Once I set it to two different values I get this:
10:20:21.666 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'systeminfo.things'
10:20:21.693 [DEBUG] [fo.internal.handler.SysteminfoHandler] - High prioriy tasks will not be run anymore !
10:20:21.694 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Medium prioriy tasks will not be run anymore !
10:20:21.695 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Start initializing!
10:20:21.701 [DEBUG] [teminfo.internal.model.OSHISysteminfo] - OSHISysteminfo service starts initializing
10:20:21.792 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Systeminfo implementation is instantiated!
10:20:21.794 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Start reading Thing configuration.
10:20:21.795 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Refresh time for medium priority channels set to 60 s
10:20:21.795 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Refresh time for high priority channels set to 50 s
10:20:21.797 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'systeminfo:computer:home' has been updated.
10:20:21.801 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Properties updated!
10:20:21.801 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Schedule high priority tasks at fixed rate 50 s.
10:20:21.802 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Schedule medium priority tasks at fixed rate 60 s.
10:20:21.802 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Schedule one time update for low priority tasks.
10:20:21.803 [DEBUG] [fo.internal.handler.SysteminfoHandler] - Thing is successfully initialized!
Just tried it here, and get the same result. Whats interesting though is that if I add a new thing it works, but not if I edit an existing thing to use the same value for both properties. If I create the thing in paperUI it also works, both creating a new thing and updating an existing. So the problem doesn’t seem to be in the binding, but rather in the .things file parser.
