I’ve submitted a pull request (PR) whose purpose is to simplify the installation of the Systeminfo binding. Before this PR, the user has to manually find, download and install the correct native library for his or her operating system and processor. On most systems, the new installation involves simply putting the binding JAR in the addons folder. For ARM systems running Linux (like the Raspberry Pi, ODROID, etc.), you have to add a new config line to openhab.cfg. But no more handling of native libraries is required unless you have an exotic or very new platform for which no native library is already packaged.
Would anyone using the Systeminfo binding on Windows or any other platform take a look at the PR to help me verify that this change is good? Thank you!
Thank you very much for taking the time to test this. I found advice like this to help me correct the issue of resolving the proper native library on Windows 10, so I’ve updated the JAR file using that advice.
Thank you again. The log seemed as if the old JAR was in effect. You may have to bundle:uninstall the old one. Sorry in a rush at the moment, but I will check back in tonight or tomorrow. Your help is much appreciated.
Thank you very much, @Farhanito, for testing the proposed changes to the Systeminfo binding.
I’m now looking for someone running openHAB on Windows 7, just for a final sanity check before considering my part done. I have every reason to think it will work fine on that OS, but would like empirical evidence.
If you or anyone you know might be able to follow the steps in the PR for testing on Windows 7, I would be much obliged.
Just to confirm, you are using the 1.9.0-SNAPSHOT Systeminfo Binding, not the 2.0 binding? You used the word “thing,” which suggests you might be referring to the 2.0 binding.
The 1.x binding uses Sigar. If that runs by itself in your environment, then I don’t know what would prevent the binding from running. Do you have logs?
Yes, I am using the 2.0 binding, and I apologize for the confusion, but I’m late to the OH2 party, so I’m not fully up on the nomenclature. Should I ditch the 2.0 binding for now?
You could certainly try the 1.9 binding, but I think it could be very helpful if you provided some log files and any configuration so we can see if the 2.0 Systeminfo binding has a bug or some other setup issue.
Absolutely - I’d like to help however I can. Here are the relevant entries from openhab.log:
2016-12-05 10:25:16.725 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘systeminf:computer:openhab2’ to inbox.
2016-12-05 10:25:24.128 [ERROR] [systeminfo.handler.SysteminfoHandler] - Can not instantate Systeminfo object!
at oshi.hardware.platform.linux.LinuxBlockDevStats.(LinuxBlockDevStats.java:78)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at oshi.hardware.platform.linux.LinuxDisks.computeDiskStats(LinuxDisks.java:145)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at oshi.hardware.platform.linux.LinuxDisks.getDisks(LinuxDisks.java:93)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at oshi.hardware.platform.linux.LinuxHardwareAbstractionLayer.getDiskStores(LinuxHardwareAbstractionLayer.java:70)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at org.openhab.binding.systeminfo.model.OshiSysteminfo.(OshiSysteminfo.java:69)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at org.openhab.binding.systeminfo.handler.SysteminfoHandler.instantiateSysteminfoLibrary(SysteminfoHandler.java:112)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
at org.openhab.binding.systeminfo.handler.SysteminfoHandler.initialize(SysteminfoHandler.java:98)[198:org.openhab.binding.systeminfo:2.0.0.201612022359]
2016-12-05 12:33:32.289 [ERROR] [systeminfo.handler.SysteminfoHandler] - Can not instantate Systeminfo object!
I’ll also add that I installed Oracle Java 8 through the webup8 PPAs (because it’s not in the official Ubuntu 14.04 packages), so I think that I’m in the right environment according to the installation instructions in the OH2 documentation.
Yes, that’s right. From what I understand, LXC containers are something in between a chroot and full-on virtual machine with a separate kernel (Linux Containers - ArchWiki). I’m happy to enable additional logging or collect other logs if it will help.
