sysVinit restart does not work
I cannot restart openhab2 (final) via sudo /etc/init.d/openhab2 restart.
Starting and stopping separately works.
cwempe@raspi2a ~ $ sudo /etc/init.d/openhab2 status
status: Ignoring predefined value for KARAF_HOME
Not Running ...
cwempe@raspi2a ~ $ sudo /etc/init.d/openhab2 restart
[....] Restarting openHAB2 server: openhab2stop: Ignoring predefined value for KARAF_HOME
Can't connect to the container. The container is not running.
 failed!
Hi @christoph_wempe, I’ve opened up an issue for you at "/etc/init.d/openhab2 restart" does not restart · Issue #28 · openhab/openhab-linuxpkg · GitHub, I’ve been fairly busy over the week but I hope to get a chance to test on Saturday, any PR requests to fix the issue are welcome.
i beleive i have the same problem; “restart” won’t restart the service, just stops openhab2 and then i have to execute “start” to run the service again.
$ sudo service openhab2 status
Running ...
$ date
Thu Feb  2 15:18:48 UYT 2017
Running ...
$ sudo service openhab2 restart
start: Ignoring predefined value for KARAF_HOME
. ok
$ date
Thu Feb  2 15:27:23 UYT 2017
$ date
Thu Feb  2 15:36:18 UYT 2017
Not Running ...
$ date
Thu Feb  2 15:36:28 UYT 2017
thanks,
max.
Hi @maxplay and all, this should be fixed in the latest snapshots. See Pull Request #31.
If you don’t want to upgrade to unstable, you should be able replace /etc/init.d/openhab2 with this version. Make sure you backup the old one first, just in case!
Great!
It seems to work.
Thanks!
here too..
[....] Restarting openHAB2 server: openhab2[....] Stopping openHAB2 server: openhab2stop: Ignoring predefined value for KARAF_HOME
Waiting for the process to stop
. ok
[ ok ] Starting openHAB2 server: openhab2.
great!, thank you!
maxplay
