Hello folks,
I am currently testing a Souliss setup with Openhab. I have a T19 (single channel dimmer) Thing.
I use openhab 2.10 with the Souliss binding add-on 1.10.0. All my Things are autodiscovered.
When i try to control the intensity of my through the PaperUI, nothing happens. the on/off command is sent properly, though. Now when i set the intensity twith Soulissapp, the slider in the paperui follows the set value.
With wireshark i found out that when i try to control the T19, Openhab does not send a command. In the logs i get an errormessage like this:
2017-11-19 15:11:47.258 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘OFF’ for item ‘Ledwall_OnOff’ to handler for channel ‘souliss:t19:1-2:onoff’, because no thing with the UID ‘souliss:t19:1-2’ could be found.
2017-11-19 15:11:51.771 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Ledwall_OnOff’ to handler for channel ‘souliss:t19:1-2:onoff’, because no thing with the UID ‘souliss:t19:1-2’ could be found.
2017-11-19 15:12:23.402 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘OFF’ for item ‘Ledwall_OnOff’ to handler for channel ‘souliss:t19:1-2:onoff’, because no thing with the UID ‘souliss:t19:1-2’ could be found.
2017-11-19 15:12:26.058 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Ledwall_OnOff’ to handler for channel ‘souliss:t19:1-2:onoff’, because no thing with the UID ‘souliss:t19:1-2’ could be found.
2017-11-19 15:22:50.562 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling handler: java.lang.NumberFormatException: For input string: "214.2"
java.util.concurrent.ExecutionException: java.lang.NumberFormatException: For input string: “214.2”
I suppose this is a bug in the binding? does anyone have an idea on how to fix or workaround this?
Thanks,
Stef
