I use the so called “tabbed page” as starting page for a GUI on a 10" full HD screen (portrait mode)
The tabs are considered the ‘primary’ navigation controls for the different sections.
Unfortunately the tab bar and text are quite small. Is there way to configure the height of the
tab-bar and font/icon size of the tabs ?
From the tabbed page wizard, I actually don’t think that there is any way to do this. You would have to build your own tabs/tab-bar on a layout page or a widget.
The basic structure using the f7 tabbar could look something like this:
Not explicitly, but anything you can display on a page, you can also build in a custom widget. So, if you want to go this route, then you can just mock up your page with the page editor, switch over the the code tab and paste that code into the widget.
Then you just have another page and the only widget you put on that page is this big tabbed widget.
It’s not a perfect system, but it might be your best option.
I think the main issue that your dealing with is that because you’re running your small screen off what is technically not a mobile device, the f7 library is using the styles desktop optimized styles. You could also see if changing the user agent info in the browser to simulate a mobile device would get you a better set of default styles without having to build everything yourself.
Not really. The tabbar sizes are set by the global f7 css variables and because of the way the tabbed pages are constructed there is no way for a user to over-ride those variable values at the level of the tab page tabbar.
