Tables are created but they are empty
I have setup a new OH3 system and one of my first things is to configure the persistence.
Infos:
  • openHAB 3.1.0 in Docker @ Synology NAS
  • MariaDB @ Synology NAS
  • Homematic CCU3
  • Philips Hue
The issue:
Tables with “item names” (Tablename Realname Generation : enabled) were only created after I press the “analyse” button and one table “Item” with item names was created.
But the item tables are empty. Did I forget to setup something? Probably…
First I had no jdbc.persist file and now I have tested it with different content like:
Strategies {
  everyMinute : "0 * * * * ?"
  default = everyMinute
Items {
    * : strategy = everyMinute
After every change I have restarted the container. In the log I can only find INSERTs for the “items” table.
Thanks for any help!!!
Now I got my first error message:
openhab> log:display org.openhab.persistence.jdbc
openhab> log:set org.openhab.persistence.jdbc
Error executing command: No enum constant org.apache.karaf.log.core.Level.ORG.OPENHAB.PERSISTENCE.JDBC
openhab> log:log org.openhab.persistence.jdbc
openhab> log:tail org.openhab.persistence.jdbc
09:35:01.023 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: item is ogBuroHeizungsregler_Ac
tualTemperature
09:35:01.025 [DEBUG] [.persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' n
umberDecimalcount='3' table='ogburoheizungsregler_actualtemperature_0002' item='ogBuroHeizungsregler_Actual
Temperature (Type=NumberItem, State=22.1 °C, Label=Actual Temperature, Category=Temperature, Tags=[Measurem
ent, Temperature], Groups=[ogBuroHeizungsregler, gruppe_persistenz_10m_speichern])' itemName='ogBuroHeizung
sregler_ActualTemperature'
09:35:01.027 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter
= org.openhab.core.persistence.FilterCriteria@1566a674, numberDecimalcount = 3, table = ogburoheizungsregle
r_actualtemperature_0002, simpleName = ogBuroHeizungsregler_ActualTemperature
09:35:01.032 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value
 FROM ogburoheizungsregler_actualtemperature_0002 WHERE TIME>'2021-11-17 09:35:01' AND TIME<'2021-11-18 10:
35:01' ORDER BY time ASC
09:35:01.032 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT ti
me, value FROM ogburoheizungsregler_actualtemperature_0002 WHERE TIME>'2021-11-17 09:35:01' AND TIME<'2021-
11-18 10:35:01' ORDER BY time ASC
09:35:01.098 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: query for ogBuroHeizungsregler_
ActualTemperature returned 0 rows in 74 ms
09:35:02.952 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: item is ogBuroHeizungsregler_Ac
tualTemperature
09:35:02.953 [DEBUG] [.persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' n
09:35:02.959 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter
= org.openhab.core.persistence.FilterCriteria@57183976, numberDecimalcount = 3, table = ogburoheizungsregle
09:35:02.971 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value
 FROM ogburoheizungsregler_actualtemperature_0002 WHERE TIME>'2021-11-17 10:35:02' AND TIME<'2021-11-18 10:
35:02' ORDER BY time ASC
09:35:02.974 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT ti
me, value FROM ogburoheizungsregler_actualtemperature_0002 WHERE TIME>'2021-11-17 10:35:02' AND TIME<'2021-
11-18 10:35:02' ORDER BY time ASC
09:35:02.984 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: query for ogBuroHeizungsregler_
ActualTemperature returned 0 rows in 32 ms
What I have also observed is that I see no log ( log:tail org.openhab.persistence.jdbc) when a item value changes. When I try to analyse a value I get this log, what is fine because no data is stored so far.
14:59:59.020 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: item is Sensortest_Motion
14:59:59.029 [DEBUG] [.persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDeci
malcount='3' table='sensortest_motion_0016' item='Sensortest_Motion (Type=SwitchItem, State=ON, Label=Motion, Catego
ry=Motion, Tags=[Point], Groups=[Sensortest])' itemName='Sensortest_Motion'
14:59:59.029 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter = org.ope
nhab.core.persistence.FilterCriteria@4775b48d, numberDecimalcount = 3, table = sensortest_motion_0016, simpleName =
Sensortest_Motion
14:59:59.030 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value FROM sen
sortest_motion_0016 WHERE TIME>'2021-11-17 15:59:59' AND TIME<'2021-11-18 15:59:59' ORDER BY time ASC
14:59:59.030 [DEBUG] [enhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value
 FROM sensortest_motion_0016 WHERE TIME>'2021-11-17 15:59:59' AND TIME<'2021-11-18 15:59:59' ORDER BY time ASC
14:59:59.032 [DEBUG] [.jdbc.internal.JdbcPersistenceService] - JDBC::query: query for Sensortest_Motion returned 0 r
ows in 4 ms
You haven’t asked for that in your persist file.
That’s true!
But adding “everyChange” does not fix the issue that no "INSERT"s are in the log.
My new persit file:
Strategies {
Items {
    * : strategy = everyMinute, everyChange
In OH3 there is a default strategy that should persist lots. This kicks in the absence of a suitable .persist file.
If you ‘delete’ your persist file (rename to blah.persist.xxxx or something) then reboot, see what happens.
If it persists then, you have a persist config problem. These files are picky about character encoding.
If not, it’s something more basic about the service, connectivity or something.
You can also persist at will from rules
someItem.persist("jdbc")
and observe your DEBUG logging.
Thank you for your efforts!
I have executed the command with and without my jdbc.persist file:
openhab> Sensortest_LastUpdated.persist("jdbc")
Sensortest_LastUpdated.persist(jdbc)
openhab>
and I got NO output with this command:
Any other idea? :pensive:
After two nights investigating, I have reinstalled OH3. And the persistence works. :scream:
I don’t know what went wrong in my first setup.
