Tablet UI's
Hi Team
Getting to the point with OH2, where I’m looking at the next step in my use case. And so fare, Openhab has been a positive experience. It is true it has a learning curve, and the documentation is not 100% - at least not so I find it easy to use. But the community is very helpful and is taking over where the documentation is missing. So a big thank you to the community.
My use case:
Standing at the front door about to leave, it should be easy to see, in some easy way, if all windows are closed.
I have got windows sensors working, got a sitemap working that shows status.
I had envisioned, an old android tablet, which just shows ‘yes’ or ‘no’ (Green or Red,…..), taken from OpenHab.
So, how is this done in the easiest way with OpenHab ?
Tablet solutions
These are the different UI that I have found.
Dashning UI
Pro:
-Has a very nice UI, and looks very good.
Cons:
-As I understand, this is build outside of OH, and you have to install a new server and ‘infrastructure’ for running this.
-You must develop/program widgets.
-And the framework it is based on, has the development on this stopped ?
Android Phone/ Apple phone app
Standard OH app, defaulting to standard or simple sitemap
Pro:
-Very easy to setup.
Cons:
-Some of the other UI, seems nicer.
Sitemap in browser
Pro:
-Very simple to configure
-100% part of the OH setup
Cons:
-Locked to the row layout of OH.
Project Rotini
Pro:
-Looks good.
Cons:
-Still in beta.
-Another external setup, with new servers (?), and new widgets
openhab-controlpanel
Pro:
-Looks like a nice simple UI for tables.
Cons:
-External server. Need to setup infrastructure for this.
-Abandoned project?
HABPanel
http://docs.openhab.org/addons/uis/habpanel/readme.html
Pro:
-Looks fine
-Part of the OH setup
Cons:
-Still need to create widgets.
So – staying inside the OH framework, is the conclusion:
Easiest
– Use Android client with simple sitemap, or browse a simple sitemap.
Best tailored
– using HabPanel
You might want to check out Imperihome - http://www.evertygo.com/imperihome Started using it with my Vera and migrating over to my OH2 using the OH2 binding - openhab2-addons/addons/io/org.openhab.io.imperihome at master · pdegeus/openhab2-addons · GitHub
It’s a flexible framework and can integrate with other systems (like Sonos or Vera) as well.
