Openhab 3.4
I want to integrate the TADO Thermostat via Openhab in Homekit
But i Get the Error
Wrong value HEAT for CurrentHeatingCoolingMode characteristic of the item Wohnzimmer_Soll_temperatur_current_mode_Homekit. Expected one of following [OFF, HeatOn, CoolOn]. Returning OFF.
Number:Temperature Wohnzimmer_inside_temperature "Temperatur" <temperature> (Wohnzimmer){ channel="tado:zone:1:Wohnzimmer:currentTemperature" }
Number Wohnzimmer_humidity "Feuchtigkeit" <Humidity> (Wohnzimmer){ channel="tado:zone:1:Wohnzimmer:humidity" }
Number Wohnzimmer_heating_power "Heizleistung" <heating> { channel="tado:zone:1:Wohnzimmer:heatingPower" }
String Wohnzimmer_hvac_mode "Heizen" <switch> { channel="tado:zone:1:Wohnzimmer:hvacMode" }
Number:Temperature Wohnzimmer_target_temperature "Sollwert" <temperature> { channel="tado:zone:1:Wohnzimmer:targetTemperature" }
DateTime Wohnzimmer_overlay_expiry "Ende man. Heizen" <time> { channel="tado:zone:1:Wohnzimmer:overlayExpiry" }
Number Wohnzimmer_timer_duration "Timer" <time> { channel="tado:zone:1:Wohnzimmer:timerDuration" }
String Wohnzimmer_operation_mode "Modus" { channel="tado:zone:1:Wohnzimmer:operationMode" }
//Homekit
Group gWohnzimmer_Thermostat "Wohnzimmer Thermostat" {homekit="Thermostat"}
Number Wohnzimmer_Ist_temperatur_Homekit "Wohnzimmer Ist Temperatur [%.1f °C]" (gWohnzimmer_Thermostat) {homekit="Thermostat.CurrentTemperature" [minValue=10.5, maxValue=30], channel="tado:zone:1:Wohnzimmer:currentTemperature" }
Number Wohnzimmer_Soll_temperatur_Homekit "Wohnzimmer Soll Temperatur [%.1f °C]" (gWohnzimmer_Thermostat) {homekit="Thermostat.TargetTemperature" [minValue=10.5, maxValue=27], channel="tado:zone:1:Wohnzimmer:targetTemperature" }
String Wohnzimmer_Soll_temperatur_current_mode_Homekit "Wohnzimmer Mode" (gWohnzimmer_Thermostat) {homekit="Thermostat.CurrentHeatingCoolingMode" [OFF="Off", HeatOn="HEAT", CoolOn="COOL"], channel="tado:zone:1:Wohnzimmer:hvacMode" }
String Wohnzimmer_Soll_temperatur_target_mode_Homekit "Wohnzimmer Mode" (gWohnzimmer_Thermostat) {homekit="Thermostat.TargetHeatingCoolingMode" }
How the Mapping should be [OFF=“Off”, HeatOn=“HEAT”, CoolOn=“COOL”]?
And which thing has to be link to homekit="Thermostat.TargetHeatingCoolingMode?
