Hi Ondrej,
I finally received my Connexoon box and I’m running into issues quite early.
2018-01-20 14:57:28.546 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.reflect.GeneratedConstructorAccessor411.newInstance(Unknown Source) [?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1944) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1939) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1938) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1508) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:140) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:425) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.access$0(SomfyTahomaBridgeHandler.java:422) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler$1.run(SomfyTahomaBridgeHandler.java:98) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
It looks like I can’t login with my credentials which I have created via https://www.somfy-connect.com.
Also if I try to login through the website https://www.tahomalink.com . I’m receiving wrong user or password.
The mobile app is working fine for me with user and password.
Do you have any recommendation what to check?
Best regards
Timmi
