I finally received my Connexoon box and I’m running into issues quite early.
2018-01-20 14:57:28.546 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.reflect.GeneratedConstructorAccessor411.newInstance(Unknown Source) [?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1944) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1939) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1938) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1508) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:140) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:425) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.access$0(SomfyTahomaBridgeHandler.java:422) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler$1.run(SomfyTahomaBridgeHandler.java:98) [234:org.openhab.binding.somfytahoma:2.3.0.201801112201]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
I’ve got the binding set up with some Venetian blinds and it all seems to work great. Thanks to those who made the binding it’s awesome.
I there a way to send a small increment to the blinds??? I can do this with the RTS remote or the app.
I want to be able to tilt the blinds and at the moment, I can either open fully or close fully or use the ‘my’ setting. It’s not enough as I want to have different amounts of tilt that I set based on the weather.
The Orientation channel seems to only work as a switch. So it can be either “open” or “closed”. I tried it as a dimmer type but got the error
“2018-02-18 16:25:06.499 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot send apply command setOrientation with params [19]!
java.io.IOException: Server returned HTTP response code: 400 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/apply
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendDataToTahomaWithCookie(SomfyTahomaBridgeHandler.java:569) [239:org.openhab.binding.somfytahoma:2.3.0.2018011521
45]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendCommandInternal(SomfyTahomaBridgeHandler.java:610) [239:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendCommand(SomfyTahomaBridgeHandler.java:593) [239:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaVenetianBlindHandler.handleCommand(SomfyTahomaVenetianBlindHandler.java:70) [239:org.openhab.binding.somfytahoma:2.3.0.2018011521
45]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]…”
OK, it seems that RTS venetian blinds use another command for the orientation setting. Can you please PM me your getSetup response (you can see it during binding initialization on DEBUG)
thanks
Ondrej
Cannot send apply command setClosure with params [0]!
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendDataToTahomaWithCookie(SomfyTahomaBridgeHandler.java:569) [195:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendCommandInternal(SomfyTahomaBridgeHandler.java:610) [195:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendCommand(SomfyTahomaBridgeHandler.java:593) [195:org.openhab.binding.somfytahoma:2.3.0.201801152145]
I used OH 2.1 and an older Snapshot from you before, and I didn’t get this excpetion. Do you know if this exception is critical. As far as I can see my shutters work as expected..
sorry to hear you have problems with my binding.
Could you please tell me, what exact device are you using? It seems it sends a command which is not recognized. I guess you are using a dimmer item and you want to open the device (rollershutter, awning etc)
Does it work for up and down commands?
The error occurred directly when starting OH without any interaction.
I’ve set the log level to TRACE (which works, I can see your log messages) but the error no longer occurs. I’ll keep an eye on it.
Is there a place to get the most recent sources? I could do some remote debugging if the error turns up again.
Best regards
Benjamin
Hi all,
I just read this exciting thread, because I’m planning to buy a Somfy shutter.
To buy the right stuff, I would like to know if it is sufficient to buy an io engine only, or do I need anything else e.g. a Tahoma gateway, to integrate the shutter into my openhab system?
Hi, you need a gateway for using this binding. Not sure if there’s some other option than Connexoon or Tahoma, but these both gateways are confirmed to be working.
Thanks.
Ondrej
Hi Ondrej,
thanks a lot for your quick response. I will buy the connexoon io box.
Is there some documentation available how to install your binding?
The bindings I installed so far were installed by using PaperUI.
if you want to manually add a new binding not included in the official distribution, just copy the binding .jar file to addons directory of your OpenHAB installation.
of course I can add it.
What channels are useful for you? What about
TargetTemperatureState (read/write)
SetPointHeatingValueState (read)
BatteryLevelState (read)
I am not sure if I understand correctly the difference between TargetTemperatureState and SetPointHeatingValueState. The TargetTemperatureState is the temperature you want to achieve and SetPointHeatingValueState is the current TRV temperature?Unfortunately both show 20.0 degrees C.
Can you confirn this, please?
Ondrej
since some time, I’m getting the below errors, resulting out of a missing cookie it seems.
Sometimes, the binding recovers connectivity, sometimes it seems to lose it, so I need to restart it.
I would be happy if you could share any advise how to avoid those?
thanks in advance,
Kurt
2018-04-15 08:45:03.606 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:140) [232:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateThingState(SomfyTahomaBridgeHandler.java:450) [232:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:435) [232:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.access$0(SomfyTahomaBridgeHandler.java:422) [232:org.openhab.binding.somfytahoma:2.3.0.201801152145]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler$1.run(SomfyTahomaBridgeHandler.java:98) [232:org.openhab.binding.somfytahoma:2.3.0.201801152145]
Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getHeaderFieldKey(HttpURLConnection.java:3053) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getHeaderFieldKey(HttpsURLConnectionImpl.java:316) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:133) ~[?:?]
... 11 more
2018-04-15 08:45:03.638 [hingStatusInfoChangedEvent] - 'somfytahoma:bridge:20d4dfdc' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Cannot get login cookie
2018-04-15 08:45:03.663 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:c97f378a-32b1-4d7a-8dbe-d15f3c53d6f2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.671 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:ae7740d8-71a9-465d-b82a-d71156f9d307' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.681 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:aa30af05-ad56-4cc5-9015-9ef6a2b8ab35' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.687 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:568a1a8f-f003-46b4-838e-e146350e1b49' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.693 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:1d90d356-37ff-4088-8bb8-5d15a28c92e4' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.700 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:197095b3-fdb0-4723-ac45-f07716c6feea' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.712 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:fd4d1ed8-dad8-40b7-bfe9-a937624d066c' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.717 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:c9c5b7c3-9226-4ad4-8884-061dd3f7da65' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.724 [hingStatusInfoChangedEvent] - 'somfytahoma:gateway:20d4dfdc:1205-5986-9551' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.728 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:4710bda7-0e49-4862-9b0b-36c8c77bbfd6' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.736 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:8cb6253d-7780-42ad-87b9-243b012416f1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.739 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:4dec644e-b355-4dae-ba94-0dbf4ceaf4b4' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.746 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:c08015db-1f33-4045-a3f6-34132a7c1480' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.749 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:42db4c29-da8c-4caa-b8b2-d39d6054efe9' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.754 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:0f2157ef-2871-4702-824f-f8efe83d3cee' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.757 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:36d51160-8f92-4d2d-a293-287a9ed43d6e' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.763 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:c488cddc-d1da-43d0-b29c-362f27929a1b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.767 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:5514b859-f4d7-4ec6-b946-509f8ad5d171' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.770 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:5159bccc-c3e0-40d1-9ab6-7c186df796e8' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.773 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:8006552f-0f0d-42d5-b24d-10deb6be5fba' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.776 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:8cb6253d-7780-42ad-87b9-243b012416f1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:03.778 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:dc586df7-06cb-469d-b46b-443fceb27083' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-15 08:45:07.166 [hingStatusInfoChangedEvent] - 'somfytahoma:bridge:20d4dfdc' changed from OFFLINE (COMMUNICATION_ERROR): Cannot get login cookie to ONLINE
2018-04-15 08:45:07.178 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:c97f378a-32b1-4d7a-8dbe-d15f3c53d6f2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.194 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:ae7740d8-71a9-465d-b82a-d71156f9d307' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.205 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:aa30af05-ad56-4cc5-9015-9ef6a2b8ab35' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.212 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:568a1a8f-f003-46b4-838e-e146350e1b49' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.217 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:1d90d356-37ff-4088-8bb8-5d15a28c92e4' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.227 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:197095b3-fdb0-4723-ac45-f07716c6feea' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.236 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:fd4d1ed8-dad8-40b7-bfe9-a937624d066c' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.241 [hingStatusInfoChangedEvent] - 'somfytahoma:gateway:20d4dfdc:1205-5986-9551' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.249 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:c9c5b7c3-9226-4ad4-8884-061dd3f7da65' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.267 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:4710bda7-0e49-4862-9b0b-36c8c77bbfd6' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.275 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:0f2157ef-2871-4702-824f-f8efe83d3cee' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.279 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:5514b859-f4d7-4ec6-b946-509f8ad5d171' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.286 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:4dec644e-b355-4dae-ba94-0dbf4ceaf4b4' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.292 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:42db4c29-da8c-4caa-b8b2-d39d6054efe9' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.296 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:8cb6253d-7780-42ad-87b9-243b012416f1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.300 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:36d51160-8f92-4d2d-a293-287a9ed43d6e' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.303 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:5159bccc-c3e0-40d1-9ab6-7c186df796e8' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.306 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:8006552f-0f0d-42d5-b24d-10deb6be5fba' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.309 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:8cb6253d-7780-42ad-87b9-243b012416f1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.312 [hingStatusInfoChangedEvent] - 'somfytahoma:actiongroup:20d4dfdc:dc586df7-06cb-469d-b46b-443fceb27083' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.328 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:c488cddc-d1da-43d0-b29c-362f27929a1b' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-04-15 08:45:07.333 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:20d4dfdc:c08015db-1f33-4045-a3f6-34132a7c1480' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE```
that’s weird. What is your refresh interval and how many Somfy things do you have? I’m having 30s and it works perfectly, not errors at all with 11 devices (rollershutters)
Thanks.
Ondrej
“TargetTemperatureState” is the temperature you want it to reach (it is stored in Tahoma and is prefixed by “core:”) and you can read/write it as many time as you like.
“SetPointHeatingValueState” is the actual temperature set in the TRV. The TRV wakes up every 30 minutes (refreshWakeUpInterval) to get the TargetTemperature.
thanks for your swift reply. Exactly the same here: I’m having as well 30s refresh time with 11 Rollershutters.
I’m not using textual configuration, but PaperUI solely.
