In openhab.log I do always find groups of 4 warnings about “somfytahoma:position”. However, I have checked and found no position channels (of old somfy tahoma binding) in my environment. So, I have looked into your jar file and found in ESH-INF/thing/exteriorscreen.xml :
what about the temperature sensors?
Still not working? Please let me know if it’s OK so I can merge it to master or send me the debug log so I can fix it.
thank you very much, I think I’ve found the problem. In status response, one of your temperature sensors sends the value as a percent type, the other one as a decimal type.
I have a Connexoon and as far as I understand from this thread many people succeeded in using the Tahoma Binding to use this in OH2.
My log-file states I can’t get a log-in cookie.
Had same problem. I logged into https://www.somfy.nl/inloggen and used those credentials in the bridge. It worked flawless. But somehow the same credentials don’t work in tahomalink.com and tahomalink site doesn’t offer a password reset option.
have you tried https://accounts.somfy.com/login ? At least for me the credentials are the same and there is the posibility of “lost password”.
Ondrej
One user reported problem with Tahomalink and he has solved it by changing the password. He has confirmed he was using some special characters in his password. Isn’t this your case as well?
O.
It may sound stupid, but try a shorter password. Maybe someone decided Passwords are at max 15 characters long and cuts your password on the somfy.com login form but not at tahomalink.
I was having this issue before and now it seems to be returning - the binding seems to miss a login cookie.
2018-11-10 17:42:15.834 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.reflect.GeneratedConstructorAccessor517.newInstance(Unknown Source) [?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1944) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1939) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1938) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1508) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:140) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateThingState(SomfyTahomaBridgeHandler.java:435) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:424) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.access$0(SomfyTahomaBridgeHandler.java:411) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler$1.run(SomfyTahomaBridgeHandler.java:98) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getHeaderFieldKey(HttpURLConnection.java:3053) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getHeaderFieldKey(HttpsURLConnectionImpl.java:316) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:133) ~[?:?]
... 11 more
the lastest version introduced again getting values by calling getState command for each thing because some users were facing problems with updating states in cases when remote controls were used.
Is there any error or exception prior to getting 403 error during getting login cookie? How many Somfy things are you having? And is this the very first login cookie getting or after some time of usage?
I am operating 11 RTS rollershutters via the Tahoma Homebox.
It is after some time of usage, that the login doesn’t work anymore.
good lead - indeed the getStates Command seems to be the root cause (?).
2018-11-10 07:49:46.120 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot send getStates command!
javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1002) [?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) [?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) [?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) [?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) [?:?]
at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:846) [?:?]
at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:678) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1587) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendDataToTahomaWithCookie(SomfyTahomaBridgeHandler.java:551) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.getAllStates(SomfyTahomaBridgeHandler.java:299) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateThingState(SomfyTahomaBridgeHandler.java:436) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
Caused by: java.io.EOFException: SSL peer shut down incorrectly
and then resulting in the logs I posted above:
2018-11-10 07:51:12.078 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1334) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1309) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:259) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:127) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at sun.security.ssl.InputRecord.read(InputRecord.java:505) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
It seems you are facing an exception during SSL handshake, which is not directly bound to this binding but network layer.
Try setting the bridge’s Status timeout property to higher value (3600+) so it lowers the communication frequency with Tahoma cloud. If you want, I can update the binding so the value of 0 disables sending the getStatus completely.
