Hi Ondrej,
that didn’t do the trick - it’s producing endless errors in the logfiles. If you think the getStatus disabling would work out - then I would kindly ask you to to help and I’ll give it a try.
2018-11-18 22:07:36.623 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot send listDevices command!
java.io.IOException: Server returned HTTP response code: 400 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/getSetup
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendDataToTahomaWithCookie(SomfyTahomaBridgeHandler.java:551) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.listDevicesInternal(SomfyTahomaBridgeHandler.java:259) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.listDevices(SomfyTahomaBridgeHandler.java:245) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.startDiscovery(SomfyTahomaBridgeHandler.java:177) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.lambda$0(SomfyTahomaBridgeHandler.java:85) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-11-18 22:07:36.791 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot send getActionGroups command!
java.io.IOException: Server returned HTTP response code: 400 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/getActionGroups
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.getGroups(SomfyTahomaBridgeHandler.java:225) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.listActionGroups(SomfyTahomaBridgeHandler.java:199) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.startDiscovery(SomfyTahomaBridgeHandler.java:178) ~[?:?]
2018-11-18 22:07:45.150 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1944) [?:?]
at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1939) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1938) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1508) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:140) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:414) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.access$0(SomfyTahomaBridgeHandler.java:411) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler$1.run(SomfyTahomaBridgeHandler.java:98) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/login
at sun.net.www.protocol.http.HttpURLConnection.getHeaderFieldKey(HttpURLConnection.java:3053) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getHeaderFieldKey(HttpsURLConnectionImpl.java:316) ~[?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:133) ~[?:?]
... 10 more
2018-11-18 22:07:45.289 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Cannot send getStates command!
java.io.IOException: Server returned HTTP response code: 400 for URL: https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/getStates
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) [?:?]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.sendDataToTahomaWithCookie(SomfyTahomaBridgeHandler.java:551) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.getAllStates(SomfyTahomaBridgeHandler.java:299) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateThingState(SomfyTahomaBridgeHandler.java:432) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
at org.openhab.binding.somfytahoma.handler.SomfyTahomaBridgeHandler.updateTahomaStates(SomfyTahomaBridgeHandler.java:424) [220:org.openhab.binding.somfytahoma:2.2.0.201712031935]
Thanks!
Kurt
