I’m completely new to OpenHab and I have so far managed to connect all my hue lights and it’s working perfectly.
I’m having a strange issue with a Tapo C100 camera though.
I’ve managed to connect it using the IPCamera Binding and have set up items using its channels, but for some reason it seems to disconnect and then reconnect in a loop - roughly every second or so.
I am experiencing the same issue. I have a working Tapo C100 (it shows correctly in my Synology Surveillance system). OpenHAB discovered the camera automatically. I provided valid login credentials for the camera account. Next thing, OpenHAB got into an infinite connect-disconnect loop every second or so.
Did anyone else have the same issue with Tapo wifi cams and found a solution?
