Hi! I am using openHAB 4.2 and a couple of Tapo device (plugs and lighs). Since a couple of days openHAB can not connect to the P110 plugs, I receive the following message:
COMMUNICATION_ERROR
cant create handshake (1100)
The events log show this messages:
2024-07-24 10:20:32.059 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘tapocontrol:P110:de2c94f5cb:5C628B86F980’ changed from OFFLINE (COMMUNICATION_ERROR): cant create handshake (1100) to UNKNOWN
2024-07-24 10:20:34.068 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘tapocontrol:P110:de2c94f5cb:5C628B86F980’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): cant create handshake (1100)
I have the same issue here, also with a P110, Firmware Version 1.3.1 Build 240621 Rel.162048 and TapoControl Binding 4.2.1 and the KLAP protocol activated in the advanced settings…
Hi
Found a solution which fixed it for me. Keyword is “TP-Link Simple Setup”. I was very frustrated because I had the latest versions of all of it: P110M devices as well as OH 4.3.3 but I always got the handshake error with the second devices. Actually, the first added device of TP-Link was helping the second device and that was the problem. Removed every TP-Link / tapo device, added each device separately through the app and handshake worked. https://community.home-assistant.io/t/tapo-devices-fail-to-connect/675178/37
The username is case sensitive, and my account seems to use the email with the first letter in uppercase. After updating the bridge config with the same capitalization, it worked
