Hi all,
I have installed Tapo bindig and I have configured it using the example provided in the TapoControl Bindig page.
This is my tapocontrol.thigs:
tapocontrol:bridge:myTapoBridge "Tapo Cloud-Login" [ username="xxx@xxx.com", password="PWD" ]
tapocontrol:P100:myTapoBridge:smartPlug1 "Tapo SmartPlug1" [ ipAddress="192.168.1.60", pollingInterval=30 ]
Ad this is my tapocontrol.items:
Switch TapoSmartPlug1 "Tapo P100 Smart Plug [%s]" { channel="tapocontrol:P100:myTapoBridge:smartPlug1:actuator#output" }
From the UI I can se that my item TapoSmartPlug1 don’t have bridgeUID set.
I have this error in the log file:
2021-12-27 20:48:38.468 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'tapocontrol.items'
2021-12-27 20:48:38.599 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.thing.internal.ChannelLinkNotifier@1390ffa" about the "ADDED" event: null
at org.openhab.binding.tapocontrol.internal.device.TapoDevice.queryDeviceInfo(TapoDevice.java:320) ~[?:?]
at org.openhab.binding.tapocontrol.internal.device.TapoSmartPlug.handleCommand(TapoSmartPlug.java:73) ~[?:?]
at org.openhab.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:177) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.lambda$3(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.call(ChannelLinkNotifier.java:96) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:367) [bundleFile:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutAddedElement(AbstractRegistry.java:400) [bundleFile:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutAddedElement(ItemChannelLinkRegistry.java:138) [bundleFile:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutAddedElement(ItemChannelLinkRegistry.java:1) [bundleFile:?]
at org.openhab.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:175) [bundleFile:?]
at org.openhab.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) [bundleFile:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:60) [bundleFile:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:79) [bundleFile:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:83) [bundleFile:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:106) [bundleFile:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:212) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:407) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:128) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) [bundleFile:?]
at org.openhab.core.service.WatchQueueReader.run(WatchQueueReader.java:240) [bundleFile:?]
How can I set it from the config file ?
Bye Mirko
