Hello all
I recently bought from a well known auction site a TCL LIFE Home automation kit (It was cheap) The App won’t install on my android system as it says it needs android v4. (Probably why it was cheap) So I thought i’d try installing OpenHAB as a learning exercise. I also have several Sonoff devices with Tasnota on them which were a breeze.
The Motion sensor though pairs and gets node discovery completed then shows several channels but these channels never seem to change.
So I have obtained from OpenHAB the fingerprint here
openhab> zigbee fingerprint 00158D00017A2AEA
|>| Node Descriptor
| |> Logical Type END_DEVICE
| |> MAC Capabilities [REDUCED_FUNCTION_DEVICE]
| |> Stack Compliance 0
| |> Server Capabilities []
| |> Buffer Size 127
| |> Incoming Transfer Size 100
| |> Outgoing Transfer Size 100
|>| Power Descriptor
| |> Available Power Sources [DISPOSABLE_BATTERY]
| |> Current Power Source DISPOSABLE_BATTERY
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest TIMEOUT
| |> IeeeAddressRequest UNKNOWN
| |> ManagementLqiRequest TIMEOUT
| |> ManagementRoutingRequest TIMEOUT
|>| Basic Information
| |> Generic Device Class
| |> Generic Device Type
| |> Manufacturer Name TCL
| |> Model Indentifier MS01
| |> Product Code
| |> Product URL
| |> Date Code 00010025
| |> Application Version 1
| |> Software Build ID
| |> Hardware Version 1
| |> Zcl Version 1
| |> Stack Version 2
| |>| Endpoint 1
| | |> Profile 0104 ZIGBEE_HOME_AUTOMATION
| | |> Device Type 0402 IAS_ZONE
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> FAILURE
| | | | |>| Attribute Values
| | | | | |> FAILURE
| | | |>| Cluster 0001 Power Configuration
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0003 Identify
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0009 Alarms
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0500 IAS Zone
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster FFFF
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Client [Output]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | | |> FAILURE
| | | | | |> FAILURE
| | | | |>| Attribute Values
| | | | | |> FAILURE
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Unsupported locally
However I’m stuck at this point.
I’m wondering if it only sends a presence on movement and I need to do something to reset it. The door contact that came in the package works fine as you can see the contact-portal changes when the door is opened and closed but the motion sensors channels never change… It also came with a Camera and Hub but as I couldn’t use the app I haven’t experimented with them.
I have replaced the batteries with new ones (twice to make sure)
So is there something obvious I have missed?
Martin.
