i have no idea why it is giving me these errors
hope someone can help with the below.
getting a lot of
cannot parse input
and
could not transform
in the logs.
i no its from the reply from the matrix
OUT01FR01\r
\r
[SUCCESS]Set output 01 connect from input 01.\r
\r
Matrix-8x8> ’
i tried doing a rules file but i dont understand how it works and the logs don’t show the rule doing anything.
.item
Switch MatrixPower “power” { tcp=“>[ON:192.168.0.5:8000:‘MAP(blustream.map)’],>[OFF:192.168.0.5:8000:‘MAP(blustream.map)’]”, autoupdate=“false”}
String MatrixOut01 “out01” { tcp=“>[11:192.168.0.5:8000:‘MAP(blustream.map)’],>[12:192.168.0.5:8000:‘MAP(blustream.map)’],>[13:192.168.0.5:8000:‘MAP(blustream.map)’],>[14:192.168.0.5:8000:‘MAP(blustream.map)’],>[15:192.168.0.5:8000:‘MAP(blustream.map)’],>[16:192.168.0.5:8000:‘MAP(blustream.map)’],>[17:192.168.0.5:8000:‘MAP(blustream.map)’],>[18:192.168.0.5:8000:‘MAP(blustream.map)’]”, autoupdate=“false”}
String MatrixReply “matrix reply [%s]” { tcp=“>[192.168.0.5:8000:default]”, autoupdate=“false”}
.map
ON=PON\r
OFF=POFF\r
11=OUT01FR01\r
12=OUT01FR02\r
13=OUT01FR03\r
14=OUT01FR04\r
15=OUT01FR05\r
16=OUT01FR06\r
17=OUT01FR07\r
18=OUT01FR08\r
.sitemap
sitemap blustream label=“matrix” {
Switch item=MatrixPower label=“Power”
Switch item=MatrixOut01 label=“out01” mappings=[11=“media”, 12=“B”, 13=“C”, 14=“D”, 15=“E”, 16=“F”, 17=“G”, 18=“H”]
.rule
rule “query matrix”
Item MatrixRely received update
switch MatrixReply.state.toString {
case “OUT01FR01\r\r[SUCCESS]Set output 01 connect from input 01.\r\rMatrix-8x8> '”: MatrixOut01.postUpdate(11)
case “OUT01FR02\r\r[SUCCESS]Set output 01 connect from input 02.\r\rMatrix-8x8> '”: MatrixOut01.postUpdate(12)
2018-07-21 17:32:44.950 [ome.event.ItemCommandEvent] - Item ‘MatrixOut01’ received command 11
2018-07-21 17:32:44.969 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to 11
2018-07-21 17:32:45.430 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’ with the file ‘blustream.map’ : Target value not found in map for 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.434 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input OUT01FR01
Matrix-8x8> to match command OFF on item MatrixPower
2018-07-21 17:32:45.439 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.443 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input OUT01FR01
Matrix-8x8> to match command ON on item MatrixPower
2018-07-21 17:32:45.448 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.457 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.466 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.474 [vent.ItemStateChangedEvent] - MatrixOut01 changed from 11 to
2018-07-21 17:32:45.488 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to OUT01FR01
Matrix-8x8>
2018-07-21 17:32:45.487 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.504 [vent.ItemStateChangedEvent] - MatrixOut01 changed from OUT01FR01
Matrix-8x8> to
2018-07-21 17:32:45.510 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to OUT01FR01
Matrix-8x8>
2018-07-21 17:32:45.521 [vent.ItemStateChangedEvent] - MatrixOut01 changed from OUT01FR01
Matrix-8x8> to
2018-07-21 17:32:45.519 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.542 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.557 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.564 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
