Rule
rule "Blind"
Item Switch changed
if (Switch.state == OFF) {
sendCommand (Blind_Window_Sofa, “\u0038\u0002\u000b\u0000”)
} else if (Switch.state == ON) {
sendCommand (Blind_Window_Sofa, “\u0038\u0002\u000b\u0032”)
At the end I want to send these Hex-Codes. All are working except the first one
\u0038\u0002\u000b\u0000 --> not working
\u0038\u0002\u000b\u0023 --> working
\u0038\u0002\u000b\u0032 --> working
\u0038\u0002\u000b\u004b --> working
\u0038\u0002\u000b\u0064 --> working
Does u0000 in this case not work with REGEX? I’m not really familiar with Regular Expressions.
Though the conversation started ages ago - maybe somebody is interested in the root cause: the TCP binding is working with string interpretations which use x00 as a string delimiter. that is why you can send all hex bytes except x00. also if a x00 is contained in the hex string to send the transformation ends there - omitting the rest of the message. I try to work on a fix on that (providing a HEX-transfer mode for the binding) - if I get the IDE up and running
