As a ( very ) newcomer, I have trouble getting tcp binding working. I have a GPIO ( Pi )installed and working but I would like to output command to an ip gateway connected directly to my Luxom domotic system.
I need to be able to output true ASCII sequences like :" *S,0,2,01; " in order to switch a specific light ON or " *C,0,2,01; " to have it switched OFF.
Can someone give me a idea about the lines I need to properly insert into the OpeHAB demo files to start having tcp binding working ?
The TCPBinding provides basic support for TCP based ASCII protocols. It sends and receives data as ASCII strings. Data sent out is padded with a CR/LF.
So the ASCII part should be handled for you. Given that, per the wiki page, you have a number of settings to make in openhab.cfg. See the âConfiguration Parametersâ section for details.
Then you need to create a .map file placed in the transform folder with the contents:
ON= *S,0,2,01;
OFF = *C,0,2,01;
NOTE: Because you have leading and closing spaces you may need to surround the above in quotes or you may need to use an alternative approach using Rules to send the string with the spaces.
I have performed numerous tests but I still have a lot of problem. I am trying to understand the basic logic in order to go step by step.
TCP connection is ok and I have seen that when I send a command â*T,0,2,01;â to turn a light ON when it is OFF like a Toggle ( there is in fact no trailing blanks and every command start with an " * " and ends uip with a " ; " ), I see no reaction on the light but the message is well passed on the bus as I get an answer from my LUXOM system as " @1T,0,2,01;@1S,0,2,01 ". @1 seems to be taken as an answer from the system but what heart me at the moment is that the LUXOM system doesnât react at all trun the light ON.
I still have to play with my system before getting a clear picture of what happen but the main error, since the start of the system, is something like :
tractSocketChannelBinding] - The channel for /192.168.0.25:2300 is now connected 2016-01-13 05:36:09.078 [ERROR] [t.i.s.MapTransformationService] - opening file âgarden.luxom.map)â], >[OFF:192.168.0.25:2300:âMAP(garden.luxom.mapâ throws exception java.io.FileNotFoundException: configurations\transform\garden.luxom.map)'], >[OFF:192.168.0.25:2300:'MAP(garden.luxom.map (The filename, directory name, or volume label syntax is incorrect)
rule "Initialize knxer"
System started
sendCommand(cmdKNXER,"<knx>CMD=IAS;IA=7.7.7</knx>")
rule "Light 1 Control"
Item Light_win received command
switch(receivedCommand)
case ON:
sendCommand( cmdKNXER, "<knx>CMD=WR;GA=4/0/10;VAL=01;DLEN=0</knx>" )
case OFF:
sendCommand( cmdKNXER, "<knx>CMD=WR;GA=4/0/10;VAL=00;DLEN=0</knx>" )
NOTE: I have a personalized connection to KNX, whick I call KNXer. I use raspberrypi2 or beagle bone black with KNX stack written by me, together with a socket connection and a tcp protocol defined by me; that being the reason why Iâm playing with TCP binding.
Thanks for trying it! Just to be sure, did you test tcp/udp binding configs with multiple subconfigs (for example, both an input and output config) separated by commas?
I didnât test the âinput modeâ because in my topology openHab is the âclientâ of my âserverâ application KNXer.
Also I couldnât figure out how to, with .map, take feedbacks. In my case the On and Off state comes via different frame. The hypotetical code of the .map would be:
In fact I use the rules together with java script for the parsing, wich solves all of my problems, because the fields inside of my frame can be in different positions.
My system is now working perfectly with Domoticz. It could also be working with OpenHAB but I have not yet had time enough to make the transfer ( time to write all configuration files ).
I have tried with some bindings but without true success. What I am now using is a MQTT server between Domoticz and Luxom. As such, I have also added 1-wire temperature sensors and switches. I also have HUE lights and Arduino based water flow sensors and everything is working smoothly. OpenVPN let me do everything remote.
As soon as time will permit, I am planning to go back to OpenHAB in order to have more flexibilities.
Picture below shows part of the system but pictures could be improved ⌠Time !
Not correct. It is not that itâs obsolete and not to be used s much as itâs going to become obsolete. It wonât be supported by OH 3. However, there is not yet a replacement that will work on OH 3 so there might be a temporarily loss of support for TCP when OH 3 first comes out in a year. It wonât be a complete loss of support as there will be a way to run a stripped down OH 1/2 instance that supports OH 1 bindings and communicate with the OH 3 instance.
MQTT isnât a work around, itâs an alternative. MQTT itself works over TCP. But it works at a much higher level which means itâs much easier to work with.
There isnât enough detail above but I suspect Luc has a Luxom to MQTT gateway of some sort. I doubt Luxom uses MQTT natively.
Yes, you must have an MQTT server between the LUXOM gateway and Domoticz/OpenHAB see ( see IDX 7 ).
I had trouble with the IPHONE gateway as it is doing a reset every 12 h - a few minutes. That means you must keep your socket open by checking often ( I did it every minute ).
I am using Python script to manage the link between the two systems ( in / out ).
I managed to control Luxom using the Telnet platform in Home Assistant. I would prefer Openhab in the long run as it provides a lot more integrations.
It is quite straightforward to set up as long as you donât need feedback on the status (if I try, my IP interface âhangsâ within minutes. Switching it fully off/on is then the only solution).
Could you share some more information how you have done the MQTT set up? Is one physical device (e.g. raspberry pi) enough for running for MQTT and Openhab/Domotics/Home Assistant?
