TCP help!
Hey Guys,
i have been going though forum trying to figure out where i have gone wrong.
i am running up to date openhabian on raspberrypi3
instilled TCP/UDP binding (binding-tcp1 1.12.0) via paper ui (how ever does not show up in configuration/bindings)
have followed this this page but still can not get it working.
tcp.items
Switch Matrix “Matrix” {tcp=“>[ON:XXX.XXX.XXX.5:8000:‘PON’], >[OFF:XXX.XXX.XXX.5:8000:‘POFF’]”}
not sure what else i need to do to get this working. i can see it in the rest api but is not linked to anything so unusable.
im not sure how to change the logs to DEBUG in openhabian. log in to openhab via putty type in log:tail and i get this
-bash: log:tail: command not found
Have you created a tcp.cfg file and placed it in the SERVICES folder?
TCP is 1.X binding and not completely configurable via PaperUI.
Squid
wow that was a quick replay!!
yes i have that file in that folder but every line of text is commented out
I don;t know if this has anything to do with it, but you have smart quotes on the PON and POFF, it may just be from posting here in the forum. Try copying and pasting the line below…
By the way…are you trying to send PON and POFF strings? If so, this is not the correct way to do this.
Squid
Switch Matrix “Matrix” { tcp=">[ON:192.168.0.5:8000:'PON'],>[OFF:192.168.0.5:8000:'POFF']"}
Read the tcp binding docs about configuration and filling in the cfg file
yes that was a copy past problem
Yes this is the string that i am trying to send to the matrix to turn it on and off. i will make the map file and try again
yes i have read and reread at lest 25 times. but this time something clicked and i noticed there was 1 box that didnt have “NO” or “only on receive”
uncommitted the reconnectcron and bang a lot more in the logs for tcp. but still no way of sending on or off commands. will try map file
Yes, you will need to use a map file and make sure you install the MAP transformation service as well.
Here’s how I do it..
ITEM
Switch Ceiling_Fan "Ceiling Fan" [ "Switchable" ] {tcp=">[ON:xx.x.x.6:3040:'MAP(cfan.map)'],>[OFF:x.x.x.6:3040:'MAP(cfan.map)']"}
MAP
ON=VSW!1 96 1 6\r
OFF=VSW!1 96 2 6\r
The “/r” are to issue a carraige return after the values.
Squid
this is the log now after reboot. if that helps
2018-07-18 02:45:43.491 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘tcp.items’
2018-07-18 02:46:03.424 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The maximum buffer will be set to the default value of 1024
2018-07-18 02:46:03.426 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The interval to retry connection setups will be set to the default value of 5
2018-07-18 02:46:03.429 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to queue write operation until a channel gets connected will be set to the default value of true
2018-07-18 02:46:03.431 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The port to listen for incoming connections will be set to the default value of 0
2018-07-18 02:46:03.433 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels within an Item will be set to the default value of true
2018-07-18 02:46:03.434 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between the items with the same direction will be set to the default value of true
2018-07-18 02:46:03.436 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between directions will be set to the default value of true
2018-07-18 02:46:03.438 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to use address masks for incoming connections will be set to the default value of true
2018-07-18 02:46:03.440 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The refresh interval of the worker thread will be set to the default value of 250
2018-07-18 02:46:03.443 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The maximum time out for blocking write operations will be set to the default value of 3000
2018-07-18 02:46:03.444 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The blocking nature of read/write operations will be set to the default value of false
2018-07-18 02:46:03.446 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default value of “”
2018-07-18 02:46:03.448 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The postamble for all write operations will be set to the default value of “”
2018-07-18 02:46:03.451 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - Updating states with returned values will be set to the default value of true
2018-07-18 02:46:03.453 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The characterset will be set to the default value of ASCII
2018-07-18 02:46:03.467 [INFO ] [b.core.service.AbstractActiveService] - TCP Refresh Service has been started
2018-07-18 02:46:03.474 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Connecting the channel Channel [item=Matrix, command=ON, direction=OUT, remote=/192.168.0.5:8000, buffer=, isBlocking=false, sReconnecting=false, channel=, host=192.168.0.5, port=8000]
2018-07-18 02:46:03.730 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.0.5:8000 is now connected
still not showing up in paper or rest :frowning:
tcp.items
Switch Matrix “Matrix” [Matrix] { tcp=“>[ON:192.168.0.5:8000:‘MAP(blustream.map)’],>[OFF:192.168.0.5:8000:‘MAP(blustream.map)’]”}
blustream.map
ON=PON\r
OFF=POFF\r
oh and i also added the map transformation service as well. didnt realize i needed that
If you add to a simple sitemap does it work?
added a sitemap
blustream.sitemap
sitemap blustream label=“matrix” {
Switch item=Matrix icon=“Power”
makes for a log with lots of warnings though.
2018-07-18 03:16:21.242 [ome.event.ItemCommandEvent] - Item ‘Matrix’ received command ON
2018-07-18 03:16:21.357 [vent.ItemStateChangedEvent] - Matrix changed from OFF to ON
2018-07-18 03:16:21.841 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘PON
[SUCCESS]Set system power ON, please wait a moment…’ with the file ‘blustream.map’ : Target value not found in map for ‘PON
2018-07-18 03:16:21.847 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input PON
[SUCCESS]Set system power ON, please wait a moment… to match command ON on item Matrix
2018-07-18 03:16:21.851 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘PON
2018-07-18 03:16:21.853 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input PON
[SUCCESS]Set system power ON, please wait a moment… to match command OFF on item Matrix
2018-07-18 03:16:30.880 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ’ Done
Matrix-8x8> ’ with the file ‘blustream.map’ : Target value not found in map for ’ Done
Matrix-8x8> ’
2018-07-18 03:16:30.885 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input Done
Matrix-8x8> to match command ON on item Matrix
2018-07-18 03:16:30.893 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ’ Done
Matrix-8x8> ’
2018-07-18 03:16:30.897 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input Done
Matrix-8x8> to match command OFF on item Matrix
2018-07-18 03:18:04.991 [ome.event.ItemCommandEvent] - Item ‘Matrix’ received command OFF
2018-07-18 03:18:05.027 [vent.ItemStateChangedEvent] - Matrix changed from ON to OFF
2018-07-18 03:18:05.380 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'POFF
’ with the file ‘blustream.map’ : Target value not found in map for 'POFF
2018-07-18 03:18:05.384 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input POFF
2018-07-18 03:18:05.390 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'POFF
2018-07-18 03:18:05.395 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input POFF
2018-07-18 03:18:07.157 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '[SUCCESS]Set system power OFF.
Matrix-8x8> ’ with the file ‘blustream.map’ : Target value not found in map for '[SUCCESS]Set system power OFF.
Matrix-8x8> ’
2018-07-18 03:18:07.165 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input [SUCCESS]Set system power OFF.
2018-07-18 03:18:07.173 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '[SUCCESS]Set system power OFF.
Matrix-8x8> ’
2018-07-18 03:18:07.181 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input [SUCCESS]Set system power OFF.
it shows and works in basicUI but nothing usable in rest
i think i need to make a things file??
will look at it in a few hrs.
thanks for the much needed help @KidSquid
No, no things file needed as it is a 1.x binding.
@hmerk how do i make it accessible from rest api without linking it to a thing with paper ui?
You defined an Item with the label “Matrix” which is accessable through REST API.
From what i have done so far with rest api i thought everything needed a LinkedItems. Didnt even click to me to just try its name. Doooo
Thank you
thanks for the help guys. need more help though.
hope you can help with the below.
getting a lot of
cannot parse input
and
could not transform
in the logs.
i no its from the reply from the matrix
OUT01FR01\r
\r
[SUCCESS]Set output 01 connect from input 01.\r
\r
Matrix-8x8> ’
i tried doing a rules file but i dont understand how it works and the logs don’t show the rule doing anything.
.item
Switch MatrixPower “power” { tcp=“>[ON:192.168.0.5:8000:‘MAP(blustream.map)’],>[OFF:192.168.0.5:8000:‘MAP(blustream.map)’]”, autoupdate=“false”}
String MatrixOut01 “out01” { tcp=“>[11:192.168.0.5:8000:‘MAP(blustream.map)’],>[12:192.168.0.5:8000:‘MAP(blustream.map)’],>[13:192.168.0.5:8000:‘MAP(blustream.map)’],>[14:192.168.0.5:8000:‘MAP(blustream.map)’],>[15:192.168.0.5:8000:‘MAP(blustream.map)’],>[16:192.168.0.5:8000:‘MAP(blustream.map)’],>[17:192.168.0.5:8000:‘MAP(blustream.map)’],>[18:192.168.0.5:8000:‘MAP(blustream.map)’]”, autoupdate=“false”}
String MatrixReply “matrix reply [%s]” { tcp=“>[192.168.0.5:8000:default]”, autoupdate=“false”}
.map
ON=PON\r
OFF=POFF\r
11=OUT01FR01\r
12=OUT01FR02\r
13=OUT01FR03\r
14=OUT01FR04\r
15=OUT01FR05\r
16=OUT01FR06\r
17=OUT01FR07\r
18=OUT01FR08\r
.sitemap
Switch item=MatrixPower label=“Power”
Switch item=MatrixOut01 label=“out01” mappings=[11=“media”, 12=“B”, 13=“C”, 14=“D”, 15=“E”, 16=“F”, 17=“G”, 18=“H”]
.rule
rule “query matrix”
Item MatrixRely received update
switch MatrixReply.state.toString {
case “OUT01FR01\r\r[SUCCESS]Set output 01 connect from input 01.\r\rMatrix-8x8> '”: MatrixOut01.postUpdate(11)
case “OUT01FR02\r\r[SUCCESS]Set output 01 connect from input 02.\r\rMatrix-8x8> '”: MatrixOut01.postUpdate(12)
2018-07-21 17:32:44.950 [ome.event.ItemCommandEvent] - Item ‘MatrixOut01’ received command 11
2018-07-21 17:32:44.969 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to 11
2018-07-21 17:32:45.430 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’ with the file ‘blustream.map’ : Target value not found in map for 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.434 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input OUT01FR01
Matrix-8x8> to match command OFF on item MatrixPower
2018-07-21 17:32:45.439 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.443 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input OUT01FR01
Matrix-8x8> to match command ON on item MatrixPower
2018-07-21 17:32:45.448 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.457 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.466 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.474 [vent.ItemStateChangedEvent] - MatrixOut01 changed from 11 to
2018-07-21 17:32:45.488 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to OUT01FR01
Matrix-8x8>
2018-07-21 17:32:45.487 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.504 [vent.ItemStateChangedEvent] - MatrixOut01 changed from OUT01FR01
Matrix-8x8> to
2018-07-21 17:32:45.510 [vent.ItemStateChangedEvent] - MatrixOut01 changed from to OUT01FR01
Matrix-8x8>
2018-07-21 17:32:45.521 [vent.ItemStateChangedEvent] - MatrixOut01 changed from OUT01FR01
Matrix-8x8> to
2018-07-21 17:32:45.519 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.542 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.557 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
2018-07-21 17:32:45.564 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OUT01FR01
Matrix-8x8> ’
