Just a simple question. Does the TCP/UDP binding only work with the compatibility layer? Or should it function without it?
Because I can only get it to work with the compatibility layer installed
It’s an OH1 binding so it would need the compatibility layer as far as I understand.
It does need the compatibility layer, as it’t an OH1-Binding
Thanks for the reply. I got a bit confused with the upgrade documention. I guess there will be an OH2 binding coming out?
Maybe… but there is no need for a new binding if an old one does work correct.
