Telegram Binding and Unicode Icons
  • Platform information:
    • openHAB version: 4.0.0.M3
Hey, i use in some rules the Telegram Binding and would pimp the Message with Icons.
But I had to realize that I can only use the ones starting with 2. Is that simply so, or how can I use the rest?
https://unicode.org/emoji/charts/full-emoji-list.html
for example this work, but all this start with 1xxx dont work, some character arrives in the message, but no icon.
2139
26A0
203C
2709
	telegramAction.sendTelegram("\u2709 Wettermeldung:\n- " + triggerItemLabel + " - Mittel bis Hoch")
It is not just 1xxx it is 1xxxx. Which makes a difference.
Instead of using \u1F000 you need to use \uD83D\uDE00.
These are surrogates codes.
See e.g. Unicode character inspector: 😀 to find the code that is required ( column surrogates ).
Thanks for the information this has helped me :smiley:
