Normally sendTelegram actions are working properly and sending messages without issues, but some times after a system restart (might be after updating items file for instance, but not exclusively, I would say just after system restart for any reason) it gives “Bot not defined” errors, despite during start up sequence there is a “2018-03-31 21:21:55.240 [INFO ] [egram.internal.TelegramActionService] - Bot MyTelegramBot loaded from config file”
Looking at the logs I sometimes spot errors like:
2018-04-04 10:24:33.964 [WARN ] [ab.action.telegram.internal.Telegram] - Transport error: {}
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?]
at java.io.BufferedInputStream.fill(BufferedInputStream.java:246) [?:?]
at java.io.BufferedInputStream.read(BufferedInputStream.java:265) [?:?]
at org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) [201:org.apache.servicemix.bundles.commons-httpclient:3.1.0.7]
at org.openhab.action.telegram.internal.Telegram.sendTelegram(Telegram.java:96) [188:org.openhab.action.telegram:1.12.0.201802111741]
at sun.reflect.GeneratedMethodAccessor532.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy160.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
I don’t think it is related, I seems to me like a transient network error that should not affect bot “definition”, but I post it just in case
Once the problem appears it persists and all the sendTelegram actions fails. It used to get fixed after some OpenHAB service restarts or RaspPi reboots (some times it needs more than just one). It is very annoying. I delayed the first sendTelegram from system start a minute in order to be sure everything is up an running before trying to use the action, but it didn’t solve it.
Does anyone experienced the same issue?
