Telegram exception: GetUpdates failed with error_code 409
  • Platform information:
    • Hardware: Zotac
    • OS: Windows 10
    • Java Runtime Environment: 17
    • openHAB version: 4.0.3
Since a few day the following error fills up my log file.
2023-09-16 11:57:57.510 [WARN ] [ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
The error is repeated constantly. I have not changed anything since the error appeared.
Is there a known reason for this warning comming up suddenly and a solution?
Looks similar to the other reported problem. Do you have more than one OH instance - in this case running with the same bot id ?
Thank you! That was the problem. I had another test PC on.
