Hi Guys,
I recently get message from telegram that the gateway is unreachable, then everything works again.
What can be the reason.
Thx
Simon
2022-03-31 12:44:37.391 [WARN ] [ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 502 Bad Gateway
2022-03-31 12:45:07.338 [WARN ] [ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 502 Bad Gateway
2022-03-31 12:47:08.497 [WARN ] [ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 504 Gateway Timeout
2022-03-31 12:49:08.663 [WARN ] [ng.telegram.internal.TelegramHandler] - Telegram exception: GetUpdates failed with error_code 504 Gateway Timeout
