Hello all,
I need your help again… I would like to have a telegram message sent to me, in which all open windows are listed.
I have so far the following:
sendTelegram("bot1", "Fenster " + gWindow.members.filter[i | i.state==OPEN] + " ist offen" )
Unfortunately, this way I get the group member with all properties (Type, State, Label, Category, etc.) displayed. I would prefer to have only the label displayed.
Since it can also happen that several items are OPEN, a listing of the labels (names) would be bursting.
Does anyone have experience? Would be very pleased.
Greetings
deibich
(David)
January 5, 2021, 2:09pm
2
Take a look at the “Tutorial & Examples” section. Your scenario is described there.
To build a String containing all the names of Items that are OPEN there are two approaches: use map/reduce or use a val StringBuilder.
// StringBuilder
val StringBuilder sb = new StringBuilder
MyGroup.members.filter[ i | i.state == OPEN].forEach[i | sb.append(", " + i.name) ]
// Map/Reduce
val str = MyGroup.members.filter[ i | i.state == OPEN ].map[ name ].reduce[ s, name | s + ", " + name ]
The StringBuild approach works because we can declare it as a val but still can call methods on it to change it.
Thanks, that worked for me!
But do you know how to prevent the output NULL? Did not find anything for that.
