I have two building i have zwave equipment in, and i want both information to be in one openhab config so on building two i use Telldus V2 zwave and 433, this works perfect with temp, on/off but not with getting the energy. I just get NAN. Is this becasue the driver thinks its temp and humidity? Can i do something or is the binding not ready for this yet?
I have not tried to get this kind of data. Could you explorer a bit using the api.telldus.com. Is this a sensor or device ? Can you see the correct value in any of the replies in the api ?
If so please send me the example output and I will see if I can add it to the binding.
I will try to look at it very soon, but on travel at the moment.
In Telldus it was automaticly converted to a sensor, and openhab automaticly finds it as a sensor with the properties of temp/humidity. My guess is that maybe its a conversion fault?
It seems when you add a zwave decive, eighter if its smart plug or 5 in on sensor it will automaticly be added a device for on/off and motion detection and then a sensor for the analog values, like kwh, temp, lux and so on. See pictures.
Then openhab will automaticly find the sensors just as temp/humidity, but i think here is were it get mixed up, openhab assumes its temp/hum as i see it and will get NAN.
Did not look at the api yet as im not experiance in that, hope this will help to solve it
Dont seems to work
I would expect it to not show up as a Sensor but a Powersensor? This is not happening. Tried to delete all the things, reboot but still finding sensors with value NAN.
