Hi!
I’ve tried for a while getting my openhab-setup working but now I’m stuck.
I installed the tellstick software, and everything works (i.e. I can control my switches with the tdtool command).
I then installed openhab 1.8.3 and I can access my sitemap via the web browser. Once this was done I downloaded the latest addons and added the “org.openhab.binding.tellstick-1.8.3.jar” to the addons folder. So far so good. The teslldus core seem to start as it is suppose to (see logfile) but I can’t get my switch to work!
I get the error message
2016-06-30 16:46:08.456 [WARN ] [.w.internal.servlet.CmdServlet] - Received command ‘TOGGLE’ for item ‘Window’, but the item does not exist in the registry
My item code is:
openHab Freddy
Group Window
Switch Window “Window” {tellstick=“Window:3”}
My stitemap code is:
sitemap home label=“My Home”
Frame label=“Window” {
Switch item=Window
And the tellstick config for the device is:
device {
id = 3
name = “Window”
controller = 0
protocol = “arctech”
model = “selflearning-switch:nexa”
parameters {devices = “”
house = “17001462”
unit = “14”code = “”
system = “”
units = “”
fade = “”
Here is the output when I start openHab:
Launching the openHAB runtime…
osgi> 2016-06-30 16:38:19.060 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-06-30 16:38:24.606 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-06-30 16:38:24.747 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Disco very initialization completed.
2016-06-30 16:38:33.072 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘freddy.sitemap’
2016-06-30 16:38:33.078 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-06-30 16:38:33.701 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘freddy.items’
2016-06-30 16:38:39.320 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Class ic UI at /classicui/openhab.app
2016-06-30 16:38:44.582 [INFO ] [.b.t.internal.TellstickBinding] - Activate Thre ad[Component Resolve Thread (Bundle 98),10,main]
2016-06-30 16:38:44.593 [INFO ] [.b.t.internal.TellstickBinding] - Called with c onfig null
2016-06-30 16:38:44.596 [INFO ] [.b.t.internal.TellstickBinding] - Loading telld us-core from system default paths
2016-06-30 16:38:44.598 [WARN ] [.b.t.internal.TellstickBinding] - Will do a rei nit of listeners, no message received for 600 seconds
2016-06-30 16:38:44.600 [INFO ] [.b.t.internal.TellstickBinding] - Listeners rem oved
2016-06-30 16:38:44.870 [INFO ] [.b.t.internal.TellstickBinding] - Telldus reset
2016-06-30 16:38:44.878 [INFO ] [.b.t.internal.TellstickBinding] - Listeners res tarted
2016-06-30 16:38:44.882 [INFO ] [.service.AbstractActiveService] - Telldus Sync Service has been started
2016-06-30 16:40:06.879 [WARN ] [.o.u.w.i.render.SwitchRenderer] - Cannot determine item type of ‘Window’
org.openhab.core.items.ItemNotFoundException: Item ‘Window’ could not be found in the item registry
at org.openhab.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:80) ~[na:na]
at org.openhab.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:554) ~[na:na]
at org.openhab.ui.webapp.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:57) ~[org.openhab.ui.webapp_1.8.3.jar:na]
at org.openhab.ui.webapp.internal.render.PageRenderer.renderWidget(PageRenderer.java:158) [org.openhab.ui.webapp_1.8.3.jar:na]
at org.openhab.ui.webapp.internal.render.PageRenderer.processChildren(PageRenderer.java:121) [org.openhab.ui.webapp_1.8.3.jar:na]
at org.openhab.ui.webapp.internal.render.PageRenderer.processChildren(PageRenderer.java:138) [org.openhab.ui.webapp_1.8.3.jar:na]
at org.openhab.ui.webapp.internal.render.PageRenderer.processPage(PageRenderer.java:86) [org.openhab.ui.webapp_1.8.3.jar:na]
at org.openhab.ui.webapp.internal.servlet.WebAppServlet.service(WebAppServlet.java:127) [org.openhab.ui.webapp_1.8.3.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.handle(Server.java:350) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) 20522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnecti er_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEn .io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEnd o_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPoo _8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool 8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_65]
2016-06-30 16:40:06.887 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrie ab.model.sitemap.Switch
2016-06-30 16:40:06.890 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrie ab.model.sitemap.Switch
2016-06-30 16:40:06.894 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrie ab.model.sitemap.Switch
2016-06-30 16:40:06.896 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrie ab.model.sitemap.Switch
2016-06-30 16:40:43.436 [WARN ] [.w.internal.servlet.CmdServlet] - Received comm the item does not exist in the registry
#Any ideas?
//F
