Platform information:
- Hardware: Raspberry Pi 4
- OS: Raspian (IOTstack)
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 2.5.9
Issue of the topic: Everyday around the same time in the morning (but not exact) the kitchen humidity and temperature both read 0. I cant figure out what can be causing this and would be greatful for some suggestions. The sensor is a standard aqara temp/humidity/pressure sensor that connects via MQTT through zigbee2mqtt and mosquitto to Openhab. I have checked and there is no MQTT message in the zigbee2mqtt logs that has a zero value. So something else must be setting this value to 0. In the openhab.log i can see mapdb (strategy everyChange) storing this 0 value in the db. However I cant tell where this is coming from. From all the items that I am tracking this is the only one that behaves funny. Shortly after I get an actual reading from the sensor and all is good again. However this 0 value is messing with my graphs in Grafana as everyday there briefly is a drop to 0.
If logs where generated please post these here using code fences:
influxdb records with a 0 value
> select * from Keuken_Humidity where value = 0
time value
2021-04-19T05:05:07.401Z 0
2021-04-19T11:44:17.061Z 0
2021-04-19T12:00:00.19Z 0
2021-04-20T05:03:14.438Z 0
2021-04-21T05:00:15.218Z 0
2021-04-22T04:58:15.89Z 0
2021-04-22T05:00:00.51Z 0
2021-04-23T04:56:16.486Z 0
2021-04-23T05:00:00.542Z 0
2021-04-24T04:54:17.087Z 0
2021-04-24T05:00:00.567Z 0
2021-04-25T04:52:17.819Z 0
2021-04-25T05:00:00.589Z 0
2021-04-26T04:50:18.468Z 0
2021-04-26T05:00:00.615Z 0
2021-04-27T04:48:19.15Z 0
2021-04-27T05:00:00.64Z 0
2021-04-28T04:47:19.773Z 0
2021-04-28T05:00:00.664Z 0
2021-04-29T04:45:20.397Z 0
2021-04-29T05:00:00.689Z 0
2021-04-30T04:43:18.735Z 0
2021-04-30T05:00:00.759Z 0
2021-05-01T04:41:19.241Z 0
2021-05-02T04:39:19.991Z 0
2021-05-03T04:37:20.627Z 0
2021-05-04T04:35:21.157Z 0
2021-05-04T05:00:00.023Z 0
2021-05-05T04:34:21.893Z 0
2021-05-06T04:32:22.514Z 0
2021-05-06T05:00:00.147Z 0
2021-05-07T04:30:23.148Z 0
2021-05-08T04:28:23.757Z 0
2021-05-08T05:00:00.226Z 0
2021-05-09T04:27:24.252Z 0
2021-05-10T04:25:25.065Z 0
2021-05-11T04:24:50.972Z 0
2021-05-12T04:22:51.662Z 0
openhab.log (system time difference between influx container and openhab container of 2 hours)
2021-05-12 06:21:28.560 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Keuken_Humidity
2021-05-12 06:21:28.562 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Keuken_Humidity' with state '55.21' in mapdb database
2021-05-12 06:22:51.644 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Keuken_Humidity
2021-05-12 06:22:51.660 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Keuken_Humidity' with state '0' in mapdb database
2021-05-12 06:47:39.132 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Keuken_Humidity
2021-05-12 06:47:39.139 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Keuken_Humidity' with state '55.17' in mapdb database
