As EG_Vi_spu is of type Number, you will have to use
Echo_TTS.sendCommand("Pufferspeicher Temperatur hat " + EG_Vi_spu.state.toString + " Grad Celsius erreicht. Ohne Wärmeabfuhr schaltet die Stromproduktion in circa 15 Minuten ab.")
I got the rule working.
Problem was, that the Expire Binding was not intalled.
1 Problem is left.
The message gives me the temperature in a wrong format. Like for example 28.5 Degrees. In german it should be 28,9 Degrees because Alexa reads it like a date 28th of may. So I need to replace the “.” with a “,” or pass only 29 to Alexa.
Ang ideas how?
Here the rule:
rule "Stromproduktion"
//Item EG_Vi_spu changed
Item Dummy changed
logInfo("Test","Stromproduktion Speichertemperatur geändert, Rule Triggered")
if (EG_Vi_spu.state == NULL) return;
logInfo("Test","EG_Vi_spu.state 1 " +EG_Vi_spu.state)
logInfo("Test","Timer Status davor " +EG_Vi_spu_Timer.state)
if (EG_Vi_spu_Timer.state == ON) return; // do nothing if timer is on
logInfo("Test","Timer Status danach " +EG_Vi_spu_Timer.state)
if (EG_Vi_evrule == 100 && EG_Vi_nbrule == 100) return;
logInfo("Test","EV + NB "+ EG_Vi_evrule.state + EG_Vi_nbrule.state)
if (EG_Vi_spu.state < 20) EG_Vi_spu_Timer.postUpdate(OFF)
//else // do you need this else?
logInfo("Test","EG_Vi_spu.state 2 " +EG_Vi_spu.state)
var Number hour = now.getHourOfDay
if (hour >= 7 && hour <= 23 ) {
if (EG_Vi_spu.state > 30) {
Echo_TTS.sendCommand("Pufferspeicher Temperatur hat " + EG_Vi_spu.state + "Grad erreicht. Ohne Wärmeabfuhr schaltet die Stromproduktion in circa 15 Minuten ab.")
logInfo("Test","state > 55")
EG_Vi_spu_Timer.sendCommand(ON)
//hour = null // why set to null?
else if (EG_Vi_spu.state > 25) {
Echo_TTS.sendCommand("Pufferspeicher Temperatur hat " + EG_Vi_spu.state + "Grad erreicht. Ohne Wärmeabfuhr schaltet die Stromproduktion in circa 30 Minuten ab.")
logInfo("Test","state > 50")
//hour = null
This might work to replace the period with a comma:
Echo_TTS.sendCommand("Pufferspeicher Temperatur hat " + EG_Vi_spu.state.toString.replace(".", ",") + " Grad erreicht. Ohne Wärmeabfuhr schaltet die Stromproduktion in circa 30 Minuten ab.")
This works perfectly!
Thank you all for your help!
I am really happy with the result!
That made me chuckle. Damned machines know best ![]()
