I have created a template using the following code:
<div ng-if="itemValue('Bedroom2_Light2')=='OFF' || itemValue('Bedroom2_Light2')=='NULL'" ng-style="{opacity: 0.1}">
<span>
<widget-icon iconset="'smarthome-set'" icon="'bulb'" size="64" />
</span>
</div>
<div ng-if="itemValue('Bedroom2_Light2')=='ON'" ng-style="{opacity: 1.0}">
<div ng-init='light1={"name": "Light2", "item": "Bedroom2_Light2", "hidelabel": false, "hideonoff": true, "iconset": "smarthome-set","icon": "bulb","icon_size": "64" }'>
<span>
<widget-switch ng-model="light1" />
</span>
</div>
</div>
whenever the selected item “Bedroom2_light2” is off, the icon appears grayed, and when I switch it on, it shows the icon as Active… this is fine
but when I tried to switch OFF the “Bedroom2_light2” with the custom widget I attached the code for, it is not clickable.
If I switch the if statement on the top from ON to OFF and the other one from OFF to ON, it works and I can switch the Light. but this is not what I want to achieve, I want to custom widget to be Active when the item is ON.
Any idea
