Hi All
Can someone provide an example of this in HabPanel?
This is just Basic UI but im looking for the ability to click some text and open another window in HabPanel? Is that possible? Like a webpage.
Hi All
Yes but if you click the down button where does it take you?
I do this using the âSwitch panel with item valueâ feature of HabPanel, found in the HabPanel settings.
I just have a string value in openHAB that I push the panel names into usingâŠ
Buttons
Selection widgets
Or rules
FYI
Watch out, itâs case sensitive
Or âŠ
You can simply add a button to a panel and choose ânavigateâ as the action, then use the drop down to select the panel you want.
But whereâs the fun in that
Hi everybody,
I can not use jquery or jquery.modal.min.js. It doesnât work.
I can add bootstrap 4.0 but It did anything correctly. It did a bug in habpanel uiâŠ
This code doesnât work :
<div oc-lazy-load="['/static/jquery.min.js','/static/jquery.modal.min.js','/static/jquery.modal.min.css']">
<!-- Use a directive from TestModule -->
<test-directive></test-directive>
</div>
<!-- Modal HTML embedded directly into document -->
<div id="ex1" class="modal">
<p>Thanks for clicking. That felt good.</p>
<a href="#" rel="modal:close">Close</a>
</div>
<!-- Link to open the modal -->
<p><a href="#ex1" rel="modal:open">Open Modal</a></p>
and the next code doesnât work too :
<!-- Trigger the modal with a button -->
<button type="button" class="btn btn-info btn-lg" data-toggle="modal" data-target="#myModal">Open Modal</button>
<!-- Modal -->
<div id="myModal" class="modal fade" role="dialog">
<div class="modal-dialog">
<!-- Modal content-->
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal">×</button>
<h4 class="modal-title">Modal Header</h4>
</div>
<div class="modal-body">
<p>Some text in the modal.</p>
</div>
<div class="modal-footer">
<button type="button" class="btn btn-default" data-dismiss="modal">Close</button>
</div>
</div>
</div>
</div>
Have you got any help for me ?
Can I somehow ignore the server side formatting and get the raw number?
Reason: The Netatmo binding does not format the pressure properly (too many decimals), for example: 1007.2000122070312 hPa
itemValue(name, true) does not help, as it will only ignore a transformation.
Hello everyone
I have a slider question for Kodi volume, the normal slider in the Habpanel only sends one value per slideâŠ
What I have noticed is that through the web interfaces and the respective Kodi remote control apps, the slider sends the values while slidingâŠ
I did a read up on how this is done and found that it is achieved using the json RPC and WebsocketsâŠ
So what I would like to know if it is possible for us to implement this on the Habpanel? I am only familiar with HTML and CSS, scripting I am almost blindâŠ
any help will be appreciated thank youâŠ
i have a question regarding button as my own widget. this question is probably very easy to answer for an html crack.
how can i define that the ng-click should be valid over the whole widget? at the moment the ng-click is only active over the text height.
<div ng-if="itemValue('StateChristmasLights')=='OFF'">
<button style="background: #11acdf00; width: 100%; height: 100%"
ng-click="sendCmd('StateChristmasLights', 'ON')">
Test
</button>
</div>
<div ng-if="itemValue('StateChristmasLights')!='OFF'">
<button style="background: #0ffa07; width: 100%; height: 100%"
ng-click="sendCmd('StateChristmasLights', 'OFF')">
Test
</button>
</div>
Hello, Iâm trying to build a widget. However, I fail to integrate a background png file all over. The image shifts the text down.
thank you for your help
How to order a list by item value? I tried several things but none of them work.
Iâm trying to get a list of the top 5 highest consuming devices.
<div class="row" ng-repeat="item in itemsInGroup('gEnergyCons') | orderBy: itemValue(item.name) : reverse | limitTo: 5">
<div class="col-xs-8 text-right">{{item.label}}</div>
<div class="col-xs-4 text-left">
{{itemValue(item.name)}}W
</div>
</div>
hi everyone.
I am new to openhab and i followed the tutorial at the top, i have copied a few code snippets and have got my widget partly running. I have got a styleissue at the moment. as you can see in the picture the word âpingâ ist jumping as soon as the itemvalue changes from 2 to 3 diggits. My question is how can i get the ping to stay in the middle?
Not only that. I would set fixed widths for all of your columns, perhaps 33.33% on all, or just use col-xs-4
class. To center, use text-align: center
I want to make a custom widget, where the icon changes according to state, my second issue is that the word "ping "in the middle keeps jumping left and right, but i have already posted that issue, my third wish is to get the value to change color depending on the higt, e.g. green under 20 red over 20, state on and off works but how do i use a value
style=âpadding-left: 10px; padding-right: 10px; padding-top: 0px; padding-bottom: 0pxâ align=ârightâ ng-style="{ color: itemValue(Ping_Jarvis)>=â20â ?âredâ:âgreenâ }">{{itemValue(âPing_Jarvisâ)}}
does not work
Hi this is the code for each item
<tr>
<td colspan=3 style="padding: 0;"><h4 style="color: #aabb00; line-height: .5em;">Jarvis</h4></td>
</tr>
<tr>
<td style="border: 2px solid #76899e; border-radius: 10px;">
<table style="width: 100%;">
<tr>
<td rowspan="4" style="padding: 0px; padding-top: 0px; padding-bottom: 0px"><widget-icon align="left" iconset="'custom-icon'" icon="'jarvis-off'" size="50" state="itemValue('Online_Jarvis')=='ON' ? 'ON' : 'OFF'"></widget-icon></td>
<td style="padding-left: 10px; padding-right: 10px; padding-top: 0px; padding-bottom: 0px" text-align="center">Ping:</td>
<td style="padding-left: 10px; padding-right: 10px; padding-top: 0px; padding-bottom: 0px" align="right" ng-style="{ color: itemValue(Ping_Jarvis)>='20' ?'red':'green' }">{{itemValue('Ping_Jarvis')}}</td>
</tr>
</table>
</td>
</tr>
Where do i put the information in?
Use code fences pls
sry.
Use bootstrap grid system instead. HabPanel uses bootstrap. Then just use divs with class="col-xs-4"
and create classes instead of inline styles. Your divs need text-align: center
as I mentioned
Okay, now you got me on the wrong foot. I have absolutly no idea what you are talking about. I only copied the code and did a few changes to fit my preference, where can i read about bootstrap, to get my widget running the way i want it.
https://getbootstrap.com/docs/3.3/examples/grid/
Only very few modern websites are still using tables for layout.
Hi luckymallari,
i have managed to do the changes and its working pretty well. Now i have 2 new problems.
<h4 style="color: #aabb00; line-height: .5em;">Jarvis:</h4>
<div class="row">
<div class="col-xs-4"><span><widget-icon iconset="'custom-icon'" icon="'jarvis-off'" size="50" state="itemValue('Online_Jarvis')=='ON' ? 'ON' : 'OFF'"></widget-icon></span></div>
<div class="col-xs-4"><span align="center">Ping:</span></div>
<div class="col-xs-4"><span align="right" style="color: green">{{itemValue('Ping_Jarvis')}}</span></div>
</div>
<h4 style="color: #aabb00; line-height: .5em;">Kodi:</h4>
<div class="row">
<div class="col-xs-4"><span><widget-icon iconset="'custom-icon'" icon="'kodi-off'" size="50" state="itemValue('Online_Kodi')=='ON' ? 'ON' : 'OFF'"></widget-icon></span></div>
<div class="col-xs-4"><span align="right" style="color: green">{{itemValue('Ping_Kodi')}}</span></div>
</div>
