Does anyone else also see this error in his logs from the Tesla binding:
2025-10-18 12:13:12.987 [ERROR] [internal.handler.TeslaAccountHandler] - An exception occurred while connecting to the Tesla back-end: 'ID segment 'null' contains invalid characters. Each se>
java.lang.IllegalArgumentException: ID segment 'null' contains invalid characters. Each segment of the ID must match the pattern [\w-]*.
at org.openhab.core.common.AbstractUID.validateSegment(AbstractUID.java:105) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:76) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[?:?]
at org.openhab.core.thing.UID.<init>(UID.java:57) ~[?:?]
at org.openhab.core.thing.ThingUID.<init>(ThingUID.java:58) ~[?:?]
at org.openhab.binding.tesla.internal.discovery.TeslaVehicleDiscoveryService.vehicleFound(TeslaVehicleDiscoveryService.java:73) ~[?:?]
at org.openhab.binding.tesla.internal.handler.TeslaAccountHandler.queryVehicles(TeslaAccountHandler.java:241) ~[?:?]
at org.openhab.binding.tesla.internal.handler.TeslaAccountHandler.lambda$0(TeslaAccountHandler.java:391) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:358) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) ~[?:?]
at java.lang.Thread.run(Thread.java:1583) [?:?]
I am currently running on the latest version of openHAB 5.0.2-1 and still get this error.
The issue started beginning of the year when I was still on 4.5, but it continued when updating to 5.0 and in the meantime I even got a new car. Initially thought the new car fixed the issue, but after like 1 day or so it appeared again.
Since sporadically I seem to get updates of my car status (every x days/weeks) I wonder what this problem is and what is causing it.
I hope someone of you has seen this issue and found a way to fix it via configuration update or so.
