Hey Paul - I’m just looking at the local powerwall binding here - not the cloud one. When I place the jar file I can do a bundle:list and see TeslaPowerwall binding as active however if I go to add a new thing I don’t see teslaPowerwall as a binding option to click through. I suspect yours is in the same state- it just works because you’ve got your thing defined. for now I can just use the marketplace version as it seems to work. Something to look for in the newest code set
(nonworking version is 4.0.0.202305250958. Working version from marketplace is 3.3.0.202112220558)
Alright! Thanks for all your work @Paul_Smedley
This is great.
For anyone coming after me, the syntax for Hostname/IP Address is different than the Hostname/IP Address used for the influxDB persistence binding (this cost me 2-3 hours!)
don’t include ‘http(s)://’ with this addon, just use the raw ip-address.
(the InfluxDB requires the ‘http://’ to be included, which is just… yeah)
I’m on OH4.0.1 and everything seems to work great, except the ‘Battery SOE’ value, which I’m guessing is the Battery state of charge, correct?
What I get out of that channel is: “1.0 one” when my battery bank is fully charged.
I haven’t seen any other state of charge yet, so can’t report what happens when it may be less than 100%.
[update1] the reading is now “0.2 one” while the Tesla app shows battery still at 100%
Any ideas what this formatting means?
Thanks a lot
This is the powerwall binding? ie the local one? And a new install (vs an upgrade from an older version of the binding/OH). It’s probably due to some of the Unit of Measure changes in OH4. Try editing your item and adding a state description of:
%.1f %%
and see if that helps. Here, mine is showing 100.0 %
Perhaps I’m doing something incorrect… I’ve tried modifying the item to add:
state: pattern="%.1f %%"
yet, OH4 doesn’t let it stick.
Here’s the full item code for the Battery SOE:
label: Battery SOE
type: Number:Dimensionless
category: ""
groupNames:
- gTeslaPowerwall
groupType: None
function: null
tags:
- Point
I edit this in the OH4 gui, save and when I re-open (in the gui ‘code’ tab), my edit is gone.
I’m a complete newb at OH, so I’m open to having made any mistake.
Thanks, this is great! I’ve been searching for this exact field for ->insert an inordinately lengthy time here<- and couldn’t figure out the trick.
Two birds with one stone, thanks so much Paul!
If it makes you feel any better, I struggled to work this out too. I’ll see if I can fix this in the thing definition so it’s easier for the next newbie
Thanks a lot, I really appreciate it.
I’m now trying to figure out how to hack a widget that others have made to reflect the same thing (SOC that isn’t a float with 12 sig figs )
No problems - I’m just glad others are making use of the binding.Personally, I use the cloud binding, as it allowed me to force-charge the battery when I need to take advantage of cheap grid prices.
We don’t have intelligent grid pricing in the States (yet), so I’m not too worried about it just now.
I am carbon negative with solar anyway, so it wouldn’t make much of a difference for my facility.
If/when the time comes, It’s good to know that control is possible with the cloud api.
Curious, do you have a Tesla EV as well?
I dare not obtain a Tesla OAuth token via the online services… seems like a recipe for a stolen car to me.
It would be great to synchronize charging with solar patterns though. That’s a part of the reason I bothered with OH in the first place: automate my house so that it’s intelligent and uses power more efficiently (e.g. looking at weather patterns and ramping attic fans at the right time/temps for the right reasons and charging the vehicle when the forecast looks great - otherwise charging it during off-peak hours)
I’ll leave that here, so I don’t cause too much thread drift.
Thanks Paul, nice to meet you and much appreciate your work.
I have 2x EV’s (Tesla Model 3 and a Model Y). I’m using ChargeHQ to automate charging - in my case though - I typically charge overnight when power is cheaper. ChargeHQ can charge based purely on excess solar though - but you would need to use an OAuth token Sounds like some time soon, Tesla will officially support 3rd party apps.
Sorry, the files item rules and things file are correct also on the OH 4.0? I install the binding and i charge the files items things and rules, but i don’t see nothing in sitemaps, only a - W (i try to insert in sitempa only InstPower Site data.)
in log i see this:
2023-08-16 00:17:24.089 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'teslapowerwall:teslapowerwall:731c4bea13' changed from INITIALIZING to ONLINE
i have a problem with Grid Energy Imported, Battery Energy Imported, Solar Energy Imported
2023-09-24 18:40:48.235 [WARN ] [penhab.core.library.items.NumberItem] - Failed to update item 'TeslaPowerwall_Grid_Energy_Imported' because '47265.34831596743 kWh' could not be converted to the item unit 'W'
