I am in the process of writing a binding for OpenHab 2 for the Verisure alarm system. What works so far:
Manually adding Verisure Thing from Paper UI
Auto discovery of climate things
arm status, armedby, timestamp channels from Alarm
arming or disarming alarm (you have to configure PIN in settings)
temperature, humidity and timestamp channels from climate devices
Since I dont have any mousetraps, waterdetectors, smartplugs or any other gadgets I would be grateful if someone could log on to their verisure mypages and post the results of the following urls:
Here you have the results for the SmartPlug. I do not have any of the other devices you requested, but I would be happy to do any testing of your binding.
I would welcome a verisure binding and I’m also up for testing.
Below is the output from the Yale Doorman.
[{“date”:“I dag 07:06”,“notAllowedReason”:“”,“image”:“locked”,“name”:“”,“operational”:true,“location”:“Inngang #”,“changeAllowed”:true,“id”:“XXXXXXXX”,“label”:“Låst”,“type”:“DOOR_LOCK”,“secureMode”:false,“status”:“locked”}]
Very interesting, if you can make this work with the Yale Doorman I would have one major piece of the puzzle resolved. I’ve been holding of getting one of these since I couldn’t see a good way of integrating it with OH, if this will be resolved I’ll run out and get one.
If I see any indication of the Yale Doorman working I’ll definitely be up for testing.
I don’t know if you’ve involved in the following thread but in case it might be helpful for you I thought I’d add it: http://forum.m.nu/post28254.html
Output from my Doorman (couldn’t wait any longer so purchased and installed this weekend. Same output as @acittlau basically. Let me know if there’s a binding to try out with the lock, I’ll be happy to test it out.
I keep getting this, twice as much info as the others - first the lock status and then the alarm status:
[{“date”:“I dag 14:06”,“disarmed”:true,“notAllowedReason”:“”,“image”:“locked”,“operational”:true,“changeAllowed”:true,“label”:“Låst”,“type”:“DOOR_LOCK”,“name”:“”,“location”:“Hoveddør”,“id”:“XXXXXX”,“secureMode”:false,“status”:“locked”},{“date”:“I dag 12:09”,“notAllowedReason”:“”,“name”:“XXXXXX”,“changeAllowed”:true,“id”:1,“label”:“Frakoblet”,“type”:“ARM_STATE”,“status”:“unarmed”}]
This means that each time i run the “manual” verisure-api,js witch i found elsewhere, I get the status of the lock and not the alarm…
Hopefully this can help you in your work on your Verisure project
