After the system reboot the error was gone and I was able the communicate with the CUL as planned. IMHO, no there should be no issue.
See https://github.com/openhab/openhab/issues/4455 and pr for it.
Found out by accident that the addon “org.openhab.io.transport.serial_3.12.0.a1.jar” isn’t needed using OH2 (ONLINE) Versio, in order the use an CUL to send data to Intertechno like plugs.
Does this apply for running OH2 on a raspberry pi with Debian jessie? I found out that the lock behavior is a bit different compared to other platforms.
Yes, I’m working on a PI with OS Jessie.
…and sorry, but I don’t know what kind of “lock” behavior you are talking about.
you can find the decription of the problem in the prior discussion. When OH opens the port a lock file is created. There has been an issue with this in prior versions of the referenced nrjavaserial lib. So seems to be solved - fine.
I made another test yesterday. Unfortunately I can’t confirm that CULintertechno is working without addon org.openhab.io.transport.serial_3.12.0.a1.jar. I still have to copy it in addons and uninstall org.openhab.io.transport.serial from the distribution.
But I don’t mind as long as it works this way ![]()
OK.
Maybe my usage is different.
I did rename the .jar in the Addons folder to .jar.old. That way it shouldn’t be used.
I’m using only the “raw” commands, since I only have switches like Intertechno.
You can see whether its used or not by logging into karaf shell and submit bundle:list. Then you can see which serial binding is being used.
OK, using “bundle:list” I found that I’m still using the org.openhab.io.transport.serial_3.12.0.a1.jar".
Why is that, I did rename it to “org.openhab.io.transport.serial_3.12.0.a1.jar.old” and restarted several times.
Do I have to manualy remove it somehow?
However I did not remove anything from the distribution!
Sorry for the false statement before, that was lack of knowledge!![]()
karaf fetches all needed dependencies and puts them into an optimized folder structure. You can find it in the userdata/cache folder. That’s why OH2 needs some time to start for the first time.
As I don’t know how it is prioritized when OH2 finds two jars for the same function, I prefer to use the safe way and uninstall the original io.transport.serial from the distribution to be shure that org.openhab.io.transport.serial_3.12.0.a1.jar is being used.
Having done a complete new install (after deleting the whole openhab-folder) I tried to use the CUL-Stick again without the manually added “org.openhab.io.transport.serial_3.12.0.a1.jar”.
It works!
Binding installed via PaperUI is “binding-intertechno - 1.9.0.SNAPSHOT”.
Bundle:list shows following entries:
204 | Active | 80 | 1.9.0.201607190111 | openHAB CULIntertechno Binding
205 | Active | 80 | 1.9.0.201607190111 | openHAB CUL Transport Bundle
206 | Active | 80 | 2.0.0.201606271614 | openHAB Serial Transport Bundle
I tried to use my CUL stick in a new setup according the OpenHAB 2 documentation. The docs emphasis to run OH as user “openhab”.
I tried that however the CUL-stick didn’t work, although I had made user “openhab” member of the dialout group.
Changing the to user to run OH to “root” resulted in a working CUL-stick.
Do I need to run as root?
same for me, it only works when i start openhab2 as root.
my setting is a clean openhab2 beta5 installation.
bindings used:
- fs20, 1.9 SNAPSHOT
- fht, 1.9 SNAPSHOT
- cul transport 1.9 SNAPSHOT
- serial transport (installed as openhab2 feature)
user openhab is added to dialout group.
moreover i added -Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0 to my setenv-file without any success.
does anyone have a hint on this? is this a bug or just my unsufficient unix skills? ![]()
[ERROR] [io.transport.cul.CULLifecycleManager] - Can’t open CUL
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:100)
Caused by: gnu.io.NoSuchPortException
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
Unexpected problem updating configuration org.openhab.fs20
java.lang.NullPointerException
at org.openhab.io.transport.cul.CULLifecycleListenerListenerRegisterer.open(CULLifecycleListenerListenerRegisterer.java:21)
This issue is solved, however only for the recent nigthly snapshots and not for the beta5 version . Sorry.
I’m using Openhabian and the build #677
Do you know the particular change that solved the issue?
To my mind there are only 3 commits to master since beta5:
https://github.com/openhab/openhab-distro/compare/2.0.0.b5...master
Maybe this change ? The part where the cusom.properties is changed ?
Sadly applying that patch (possible as only configuration files are changed) to my current installation won’t work.
Nope, it was a change discussed in Here
ah i see, thanks for your info.
i’ll keep up with running as root until the next beta i.e. the final openhab2 is released.
back to topic:
with compatibility mode the 1.9 bindings work like a charm with openhab2.
i can confirm that FHT and FS20 are working in parallel with one CUL stick.
thanks for your effort @tarioch. If you need any assistance or further tests keep in touch.
I have a recent OH 2.1 SNAPSHOT installed. I use stick CULv3 (868) USB Stick with it. I have following bindings installed:
193 | Active | 80 | 1.10.0.201702010211 | openHAB CULIntertechno Binding
194 | Active | 80 | 1.10.0.201702010211 | openHAB CUL Transport Bundle
195 | Active | 80 | 1.10.0.201702022206 | openHAB S300TH Binding'
Intertechno
Intertechno commands work perfectly fine. I did not have to start as root and use the apt-get installation on a raspberry. What I had to do is to add Java extra option for the serial ports:
pi@raspberrypi:~ $ cat /etc/default/openhab2
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0:/dev/ttyACM1"
( In my setup ttyACM0 is a zwave stick and ttyACM1 is the CUL )
S300TH
But S300TH readings do not seem to work. So I have following questions:
The S300TH binding was not available via Paper UI nor via feature list in karaf. I had to checkout the openhab1-addons repo and build it locally via maven. Why is this binding not available?
When I use the screen command to put the CUL in listening mode (X21 command), I see the sensor readings of my 2 sensors ( ASH2200 ):
111462450F
0123524329
111462450F
0122524327
1115624517
012152432A
Also after setting the CUL io to package to debug I get following logs:
09:45:17.707 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: K1115924814
09:45:17.710 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
09:45:17.733 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 21 900
09:45:17.735 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 900
09:47:23.164 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: K011712462C
09:47:23.167 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
09:47:23.190 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 21 900
09:47:23.192 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 900
09:51:10.720 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: K111592480F
09:51:10.724 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
09:51:10.747 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 21 900
09:51:10.751 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 900
However, the S300TH binding seems not to be called. Do I need to configure something to get the S300TH binding added as listener to the CUL io add-on ?
my items:
Number ASH2200Temp2 "AS2200 (2) Temperatur [%.1f C]" <temperature> {s300th="address=2;datapoint=TEMPERATURE"}
Number ASH2200Temp1 "AS2200 (1) Temperatur [%.1f C]" <temperature> {s300th="address=1;datapoint=TEMPERATURE"}
Any help about the S300TH readings would be highly appreciated. Thx
OK, solved myself. My stupid error was to forget to configure the s300th binding. So in /etc/openhab2/services I added now a file called s300th.cfg with follwowing content:
device=serial:/dev/ttyACM1
Then then the binding registers itself on the already existing cul device and reacts on messages as expected ![]()
However, one question stays… Why is the s300th binding not part of the official distribution, respectively indexed as add-on to be installed via paper ui!?
