Channels are not found:
node8_new.xml (6.0 KB)
FYI: The new node8.xml is exactly the same as the one I deleted.
Do jou need a debug log of the adding of the node?
The xml file won’t change - what changes is the configuration of the channel internally within OH, but you can’t easily see this…
What I wanted to know is what happens if you try and control the light color, but you need to sort out the channels first . I had hoped it would pick up the same channels, but you might need to recreate them - the names it creates should be the same as before though so sitemaps should be ok.
A, got ya with the not chaning of the xml. Color works! as well as Color temp + dimmer. for the first time, I might add.
After a restart of openhab the channels where created+linked just not automatically after added the ‘Thing’ apparently.
I should remove + add all my RGB Bulb’s
The usual transmit errors:
2016-02-28 11:58:30.862 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 31
2016-02-28 11:58:30.879 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 31
2016-02-28 11:58:31.045 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 11:58:31.137 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 11:58:35.321 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 73
2016-02-28 11:58:35.434 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 11:58:35.501 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 73
2016-02-28 11:58:35.549 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (CAN), resending
2016-02-28 11:58:35.559 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_1530ad9faba_serial_can changed from 10 to 11
2016-02-28 11:58:35.658 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 11:58:38.151 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 51
2016-02-28 11:58:38.344 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer’ received command 51
2016-02-28 11:58:40.538 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left!
2016-02-28 11:58:40.542 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-02-28 11:58:40.644 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (CAN), resending
2016-02-28 11:58:40.644 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 11:58:40.650 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_1530ad9faba_serial_can changed from 11 to 12
2016-02-28 11:58:40.750 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
Cool - I must remember that if changes get made to channel parameters, then we need to recreate the thing, which is a bit annoying, but not as annoying as chasing a bug that’s already been solved
Very true, I am a happy camper , one warning in the log though keeps coming when changing color:
2016-02-28 12:05:22.040 [WARN ] [.commandclass.ZWaveColorCommandClass] - Unsupported Command 0x05 for command class COLOR (0x33)
and using the dimmer:
2016-02-28 12:08:15.980 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
Maybe of interest to u.
Thanks - I’ll take a look at this…
@bhuism do you have a debug log associated with these? I would like to see when they arrive in relation to the commands, and also just to confirm their content.
Finally got back to looking into the temp not updating. I’m using a 28/02 version of the binding and yesterday’s HABmin.
From what I can see in the logs things look normal (I think).
11:47:22.996 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 04 06 31 05 01 22 00 B1 53
11:47:23.003 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
11:47:23.005 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 04 06 31 05 01 22 00 B1 53
11:47:23.007 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 04 06 31 05 01 22 00 B1 53
11:47:23.008 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 04 06 31 05 01 22 00 B1
11:47:23.010 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
11:47:23.011 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class SENSOR_MULTILEVEL
11:47:23.012 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Received Sensor Multi Level Request
11:47:23.014 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Multi Level REPORT received
11:47:23.015 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Type = Temperature(1), Scale = 0
11:47:23.016 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Value = 17.7
11:47:23.017 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
11:47:23.019 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
11:47:23.020 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 17.7
11:47:23.022 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 04 05 71 04 00 00 01
11:47:23.024 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 04 06 31 05 01 22 00 B1
11:47:23.025 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
11:47:23.026 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
The rest API shows that the channel is linked to an item and the Celsius channel parameter seems to have saved:
"linkedItems": [
"sensor_1_temp"
"id": "sensor_temperature",
"channelTypeUID": "zwave:sensor_temperature",
"itemType": "Number",
"label": "Sensor (temperature)",
"properties": {
"binding:*:DecimalType": "SENSOR_MULTILEVEL;sensorType=TEMPERATURE"
"configuration": {
"config_scale": "celsius"
But the item still hasn’t been updated to the value received (that value displayed is several days old now):
openhab> status sensor_1_temp
21.300000000000000710542735760100185871124267578125
@Chris Here you go, part 1/2:
2016-02-28 12:56:22.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Command received zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer --> 33
2016-02-28 12:56:22.117 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Creating new message for command SWITCH_MULTILEVEL_SET
2016-02-28 12:56:22.119 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Creating new message for command SWITCH_MULTILEVEL_GET
2016-02-28 12:56:22.121 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
2016-02-28 12:56:22.121 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-02-28 12:56:22.122 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
2016-02-28 12:56:22.123 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 08 03 26 01 21 25 68 A6
2016-02-28 12:56:22.127 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 8: Sending REQUEST Message = 01 0A 00 13 08 03 26 01 21 25 68 A6
2016-02-28 12:56:22.131 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer' received command 33
2016-02-28 12:56:22.133 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer changed from 96 to 33
2016-02-28 12:56:22.137 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.141 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.143 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-02-28 12:56:22.144 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_ack' could not be found in the item registry
2016-02-28 12:56:22.145 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.148 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-02-28 12:56:22.149 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: Sent Data successfully placed on stack.
2016-02-28 12:56:22.152 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.158 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 68 00 00 03 80
2016-02-28 12:56:22.161 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.162 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.166 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 68 00 00 03 00 00 8E
2016-02-28 12:56:22.169 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 68 00 00 03 00 00 8E
2016-02-28 12:56:22.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 68 00 00 03
2016-02-28 12:56:22.173 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: SendData Request. CallBack ID = 104, Status = Transmission complete and ACK received(0)
2016-02-28 12:56:22.176 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 03 26 01 21
2016-02-28 12:56:22.178 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 68 00 00 03
2016-02-28 12:56:22.180 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-02-28 12:56:22.181 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.184 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.184 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 20 03 21 FB
2016-02-28 12:56:22.185 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.186 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.189 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.191 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Response processed after 63ms/624ms.
2016-02-28 12:56:22.191 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.192 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-02-28 12:56:22.194 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 08 02 26 02 25 69 87
2016-02-28 12:56:22.194 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 20 03 21 FB
2016-02-28 12:56:22.195 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 8: Sending REQUEST Message = 01 09 00 13 08 02 26 02 25 69 87
2016-02-28 12:56:22.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 20 03 21 FB
2016-02-28 12:56:22.201 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_ack' could not be found in the item registry
2016-02-28 12:56:22.201 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 20 03 21
2016-02-28 12:56:22.204 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.205 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.206 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class BASIC
2016-02-28 12:56:22.208 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.210 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 8: Received Basic Request
2016-02-28 12:56:22.212 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 8: Basic report, value = 0x21
2016-02-28 12:56:22.214 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.216 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.217 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 33
2016-02-28 12:56:22.221 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 33
2016-02-28 12:56:22.226 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 69 00 00 02 80
2016-02-28 12:56:22.227 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color changed from 0,100,100 to 0,100,33
2016-02-28 12:56:22.230 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.232 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.234 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-02-28 12:56:22.236 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.239 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.239 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-02-28 12:56:22.241 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.242 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: Sent Data successfully placed on stack.
2016-02-28 12:56:22.244 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=1
2016-02-28 12:56:22.246 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 69 00 00 02 00 00 8E
2016-02-28 12:56:22.248 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 69 00 00 02 00 00 8E
2016-02-28 12:56:22.250 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 69 00 00 02
2016-02-28 12:56:22.254 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: SendData Request. CallBack ID = 105, Status = Transmission complete and ACK received(0)
2016-02-28 12:56:22.256 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.258 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 69 00 00 02
2016-02-28 12:56:22.259 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.260 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.261 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.263 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.264 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 03 21
2016-02-28 12:56:22.265 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.266 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class SWITCH_MULTILEVEL
2016-02-28 12:56:22.267 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Received Switch Multi Level Request
2016-02-28 12:56:22.268 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Switch Multi Level report, value = 33
2016-02-28 12:56:22.270 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.271 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.272 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 33
2016-02-28 12:56:22.277 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.278 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 33
2016-02-28 12:56:22.283 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.284 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 03 21
2016-02-28 12:56:22.285 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.286 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.287 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.288 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.289 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Response processed after 93ms/624ms.
2016-02-28 12:56:22.296 [DEBUG] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at 'items/zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer' with value '33'.
2016-02-28 12:56:22.301 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating command '33' for item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer' to handler for channel 'zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer'
2016-02-28 12:56:22.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Command received zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer --> 33
2016-02-28 12:56:22.303 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Creating new message for command SWITCH_MULTILEVEL_SET
2016-02-28 12:56:22.304 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Creating new message for command SWITCH_MULTILEVEL_GET
2016-02-28 12:56:22.305 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-02-28 12:56:22.307 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 08 03 26 01 21 25 6A A4
2016-02-28 12:56:22.309 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 8: Sending REQUEST Message = 01 0A 00 13 08 03 26 01 21 25 6A A4
2016-02-28 12:56:22.310 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 0
2016-02-28 12:56:22.311 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
2016-02-28 12:56:22.312 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer' received command 33
2016-02-28 12:56:22.315 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update '33' for item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_switch_dimmer' to handler for channel 'zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer'
2016-02-28 12:56:22.318 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.320 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.321 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_ack' could not be found in the item registry
2016-02-28 12:56:22.322 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-02-28 12:56:22.323 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.324 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-02-28 12:56:22.325 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.328 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: Sent Data successfully placed on stack.
2016-02-28 12:56:22.339 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 6A 00 00 03 82
2016-02-28 12:56:22.342 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.342 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.344 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 6A 00 00 03 00 00 8C
2016-02-28 12:56:22.346 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 6A 00 00 03 00 00 8C
2016-02-28 12:56:22.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 6A 00 00 03
2016-02-28 12:56:22.349 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: SendData Request. CallBack ID = 106, Status = Transmission complete and ACK received(0)
2016-02-28 12:56:22.350 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 03 26 01 21
2016-02-28 12:56:22.353 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.356 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.358 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 6A 00 00 03
2016-02-28 12:56:22.359 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-02-28 12:56:22.360 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.361 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.362 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.364 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.365 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Response processed after 53ms/624ms.
2016-02-28 12:56:22.365 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.366 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-02-28 12:56:22.367 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.368 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 08 02 26 02 25 6B 85
2016-02-28 12:56:22.369 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.369 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 8: Sending REQUEST Message = 01 09 00 13 08 02 26 02 25 6B 85
2016-02-28 12:56:22.370 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 01 21
2016-02-28 12:56:22.372 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.374 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class SWITCH_MULTILEVEL
2016-02-28 12:56:22.375 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Received Switch Multi Level Request
2016-02-28 12:56:22.376 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 12:56:22.379 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.381 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.383 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-02-28 12:56:22.385 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-02-28 12:56:22.388 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_ack' could not be found in the item registry
2016-02-28 12:56:22.389 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-02-28 12:56:22.390 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: Sent Data successfully placed on stack.
2016-02-28 12:56:22.392 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.400 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 6B 00 00 03 83
2016-02-28 12:56:22.402 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.403 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.404 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 6B 00 00 03 00 00 8D
2016-02-28 12:56:22.406 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 6B 00 00 03 00 00 8D
2016-02-28 12:56:22.408 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 6B 00 00 03
2016-02-28 12:56:22.410 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: SendData Request. CallBack ID = 107, Status = Transmission complete and ACK received(0)
2016-02-28 12:56:22.413 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.414 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.414 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 6B 00 00 03
2016-02-28 12:56:22.416 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.416 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.420 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.423 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.425 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 26 03 21 FD
2016-02-28 12:56:22.427 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 03 21
2016-02-28 12:56:22.428 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.430 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class SWITCH_MULTILEVEL
2016-02-28 12:56:22.431 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Received Switch Multi Level Request
2016-02-28 12:56:22.432 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Switch Multi Level report, value = 33
2016-02-28 12:56:22.433 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.435 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.437 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 33
2016-02-28 12:56:22.438 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.439 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.443 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.444 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 33
2016-02-28 12:56:22.453 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.465 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 03 21
2016-02-28 12:56:22.466 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.467 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.468 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.470 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.471 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.473 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Response processed after 102ms/624ms.
2016-02-28 12:56:22.473 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.476 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.479 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 26 01 21 FF
2016-02-28 12:56:22.482 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 01 21
2016-02-28 12:56:22.484 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.486 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class SWITCH_MULTILEVEL
2016-02-28 12:56:22.488 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 8: Received Switch Multi Level Request
2016-02-28 12:56:22.490 [WARN ] [ss.ZWaveMultiLevelSwitchCommandClass] - Unsupported Command 1 for command class SWITCH_MULTILEVEL (0x26).
2016-02-28 12:56:22.492 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.494 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 26 01 21
2016-02-28 12:56:22.496 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.497 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.499 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.500 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.502 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.538 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 08 03 20 03 21 FB
2016-02-28 12:56:22.541 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-02-28 12:56:22.542 [DEBUG] [home.core.internal.items.ItemUpdater] - Received update for non-existing item: Item 'zwave_serial_zstick_1530ad9faba_serial_sof' could not be found in the item registry
2016-02-28 12:56:22.544 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 08 03 20 03 21 FB
2016-02-28 12:56:22.547 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 08 03 20 03 21 FB
Part 2/2
2016-02-28 12:56:22.549 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 20 03 21
2016-02-28 12:56:22.550 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Application Command Request (ALIVE:DONE)
2016-02-28 12:56:22.552 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Incoming command class BASIC
2016-02-28 12:56:22.553 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 8: Received Basic Request
2016-02-28 12:56:22.554 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 8: Basic report, value = 0x21
2016-02-28 12:56:22.555 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.556 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.557 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 33
2016-02-28 12:56:22.560 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-02-28 12:56:22.561 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 33
2016-02-28 12:56:22.565 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 26 02
2016-02-28 12:56:22.567 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 03 20 03 21
2016-02-28 12:56:22.568 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
2016-02-28 12:56:22.570 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - transaction complete!
2016-02-28 12:56:22.571 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-02-28 12:56:22.572 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-02-28 13:23:26.148 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/C:/JavaDev/openHAB/openhab-offline-2.0.0-SNAPSHOT/addons/org.openhab.ui.habmin_2.0.0.SNAPSHOT-0.0.15.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.ui.habmin [168]
Unresolved requirement: Import-Package: org.openhab.binding.zwave.internal.config
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1245)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1217)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:509)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:358)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:310)[8:org.apache.felix.fileinstall:3.5.0]
2016-02-28 13:23:30.757 [ERROR] [org.eclipse.smarthome.core.transform] - [org.eclipse.smarthome.action.transformation.action(79)] Circular reference detected, getService returning null
2016-02-28 13:23:32.033 [INFO ] [smarthome.event.ItemAddedEvent ] - Item ‘zwave_serial_zstick_cb97c321’ has been added.
2016-02-28 13:23:32.056 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing ‘zwave:serial_zstick:cb97c321’ has been added.
2016-02-28 13:23:32.073 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link ‘zwave_serial_zstick_cb97c321-zwave:serial_zstick:cb97c321’ has been added.
The processing of the temperature still looks a bit messed up with its handling of the arguments - I’ll try and sort this today.
No - the temporary branch needs to be merged into master which I hope to do this week.
Ah, true. i think all of the effected items are on battery.
Is there any way to list all items and their states? In old habmin i could get a list of all nodes, but i havent seen that in the new one?
At the moment, battery devices need to be through a certain stage of discovery before they are added to the inbox (actually, that’s for all devices, it’s just that for most mains devices, you don’t notice it). I’ll try and change this at some stage as there are some new features in ESH I can make use of to improve this.
No - there’s no way to get a list of devices - ideally, devices should either be in the inbox, or the list of things - at the moment, there’s this other state which means they can be no-where which I do agree is confusing…
This has been added to the database and will be in tomorrows snapshot (hopefully).
can you give some basic steps in how you got the color to work on your Aeon RGBW bulb?
This morning, I did the following but still struggling with it.
1, I updated my Zwave binding by removing the old one in the Addons folder.
2. Then Installed the Zwave 2.0 binding via PaperUI
3. Then in Habmin, I removed the bulb and then re-searched the Zwave network and it added back in.
4. And I can still control the dimmer on/off, but not the color.
Did you need to Update OH2 as well? I think i’m on the most current, but sure how I can tell which version I’m currently on.
The important thing is to remove the ‘thing’ and re-add it. This forces OH to re-read the XML database into the things configuration (which then gets stored which is why updating the database didn’t fix this when I did it on Friday).
If it’s not working, I would double check in the console that you are running the latest binding (ie yesterday or todays date).
