@chris: What happens in HABmin, when I link an item defined in an item file to a channel (using { channel=“zwave…” }. Will this link be shown as an active link in HABmin? Or does HABmin only show links between channels and DB items?
I would expect that it should show it as an active channel - you just can’t edit the item.
@chris - so now that the NOTIFICATION stuff is merged in…how do I make sue of it? At least I’m assuming it’s in the binding now as the logs are showing some messages about notification reports…here’s what I have:
16:28:15.378 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
16:28:15.384 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
16:28:15.391 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 0A 71 05 00 00 00 FF 08 01 00 00
16:28:15.393 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DETAILS)
16:28:15.395 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
16:28:15.396 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V3
16:28:15.398 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process Alarm Report, V3, length 13
16:28:15.400 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 8 = 0, sensor=0, event=1, status=255
16:28:15.401 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = POWER_MANAGEMENT (8)
16:28:15.403 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
16:28:15.405 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
16:28:15.407 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
16:28:15.411 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 3: Transaction not completed: node address inconsistent. lastSent=3, incoming=255
16:28:15.814 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0E 03 80 03 21 5D
Sorry for the dumb question as you’ve probably said, but what device is this?
@chris My bad…I should’ve been more clear…I forget that you’re juggling requests for many people.
It’s the DBZ100Z doorbell. The trick is that it always sends a value of ‘0’.
Don’t worry about this - notifications get a different value.
In the log above, we have a power management notification. I’ve added that to the device. We will need to add a bunch of new channels…
Can you provide the XML file for this device - preferably delete it, and then let it be created again with the latest binding. In theory we should now get the notification types listed - if I can get an XML then I’ll look to update things. Actually, if you can also provide a debug log, then I might use this to add a few more tests for the initialisation.
@chris I’ve attached the XML and the log file (with xml extension so it’d upload here):
DB100Z.xml (8.3 KB)
DB100Z-log.xml (344.0 KB)
Thanks. I’m going to do a bit more work on this in the next day or so since most of the implementation was written before we had the ZWave docs…
@feens as a matter of interest, why do you think this device is making use of the notification class. It doesn’t say much in the manual, and the device is reporting that its only notification is the power management events that I added in yesterdays binding… I can’t find a ‘proper’ manual though so maybe you have more information?
@chris because you said it was
Also, I found a bit of a write-up from someone who wrote the driver for SmartThings: Nexia Doorbell Sensor Review & SmartThings Device Handler (DB100Z ) - DarwinsDen.com
They said this:
The doorbell sends a version 2 Notification Report event 1 when current is detected and an event 0 when it stops. Battery level is sent in a Battery Report and is a simple integer percentage value.
Writing the device handler was a little more complex than I was expecting – primarily due to an occasional missed message and the occasional out of order message sequence. I’ve implemented code to work around these cases.
Ok, maybe I should have been clearer ;). I know it uses the notification class, but the only event it is reporting is the power management “power has been applied” event. So, my question really should have been why do you think it is using the notification class for the actual doorbell press?
Maybe this notification is the doorbell press and the device is just using a slightly strange event? If so, maybe you can comment on what happens with the latest binding which has this?
I have found a couple of mostly small issues with the notification class so will likely do an update tonight as well…
@chris Is it possible to disable polling and rely on the notifications ?
I’m thinking about doing this with my Fibaro wall plugs. Right now I’m using 30 sec polling, and it seems to be a bit excessive. Setting the polling parameter to 0 in Habmin, results in 15 seconds polling.
Polling in the OH2 binding can’t be completely disabled as it is used to check on the health of a device. If you were to only rely on notifications, then you don’t know if the device is dead - it might be dead, or it might just not be used.
This is why the binding defaults to 1800 seconds (30 minutes - you can set it longer although I forget how high it can go - I think 7200).
Absolutely - I would recommend a much longer period. As above, the default is 1800 seconds.
Yes, the binding won’t allow such a small number so it only lets you set it as low as 15 seconds.
Ok, maybe I should have been clearer . I know it uses the notification class, but the only event it is reporting is the power management “power has been applied” event. So, my question really should have been why do you think it is using the notification class for the actual doorbell press?
Well, the logs you originally commented on for it using the notification class were from when I pushed the button, so I think it’s safe to assume that it uses that for the doorbell press. The follow up log that I posted (Testing Z-Wave binding on openHAB-2 - #1450 by feens) are also of a button press, but with the binding updates.
I wonder if they use the “power has been applied” event due to the way the whole device works: when someone pushes a doorbell, it sends the current to the doorbell, and this devise is inserting it to that chain (it’s attached to the bell part of the doorbell and capturing the current), thus it essentially sends a notification when power is applied to it. Probably not the best decision for end users, but not much I can do about that.
When I first added the device to your db and got it going, I actually had it working by using “received update” in my rules (and then I use Pushover to send me notifications…very handy). Somewhere along the line of updates, the OH item started firing off that event randomly (I’m guessing when the device wakes up and reports), so I started getting random notifications. Now it doesn’t seem to trigger that event/rule at all though.
Ok - thanks. I wasn’t sure that this was from a button press, and I can’t go back looking for old logs - the forum is just not easy for tracing this sort of thing.
I will push another update later this evening that fixes a small bug - it might solve the issue.
Is there anything sent when you remove the button press, or is this the only thing sent, and it’s sent at the time the button is pressed?
@chris - it looks like there are two events (press/release). The first shows as event=1
, and the second as event=0
. I’m guessing for powers has been applied/removed. Here’s the full log output for a press/release (obviously they happen quickly with a doorbell):
12:13:43.278 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 7092 to 7093
12:13:43.278 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
12:13:43.291 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:13:43.296 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
12:13:43.300 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
12:13:43.305 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 0A 71 05 00 00 00 FF 08 01 00 00
12:13:43.307 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DONE)
12:13:43.308 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from DONE
12:13:43.310 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@122fff already registered
12:13:43.314 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
12:13:43.316 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V3
12:13:43.317 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process Alarm Report, V3, length 13
12:13:43.319 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 8 = 0, sensor=0, event=1, status=255
12:13:43.320 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = POWER_MANAGEMENT (8)
12:13:43.322 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:13:43.324 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:13:43.325 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:13:43.328 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Transaction not completed: node address inconsistent. lastSent=2, incoming=255
12:13:43.739 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:43.742 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 7093 to 7094
12:13:43.746 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:13:43.749 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:43.751 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:43.754 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 03 80 03 21
12:13:43.755 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DONE)
12:13:43.757 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from DONE
12:13:43.758 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@122fff already registered
12:13:43.760 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BATTERY
12:13:43.761 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Received Battery Request
12:13:43.762 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Battery report value = 33
12:13:43.763 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:13:43.764 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:13:43.766 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 33
12:13:43.767 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:home:node14:battery-level to 33 [DecimalType]
12:13:43.775 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Transaction not completed: node address inconsistent. lastSent=2, incoming=255
12:13:43.776 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_device_home_node14_battery_level changed from 28 to 33
12:13:44.445 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 7094 to 7095
12:13:44.450 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
12:13:44.457 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:13:44.462 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
12:13:44.470 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
12:13:44.476 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 0A 71 05 00 00 00 FF 08 00 00 00
12:13:44.481 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DONE)
12:13:44.485 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from DONE
12:13:44.490 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@122fff already registered
12:13:44.492 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
12:13:44.495 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V3
12:13:44.497 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process Alarm Report, V3, length 13
12:13:44.499 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 8 = 0, sensor=0, event=0, status=255
12:13:44.502 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = POWER_MANAGEMENT (8)
12:13:44.504 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:13:44.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:13:44.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:13:44.510 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Transaction not completed: node address inconsistent. lastSent=2, incoming=255
12:13:44.911 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:44.915 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 7095 to 7096
12:13:44.919 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:13:44.923 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:44.934 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 0E 03 80 03 21 5D
12:13:44.938 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 03 80 03 21
12:13:44.941 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DONE)
12:13:44.943 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from DONE
12:13:44.946 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@122fff already registered
12:13:44.949 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BATTERY
12:13:44.952 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Received Battery Request
12:13:44.954 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Battery report value = 33
12:13:44.956 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:13:44.959 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:13:44.961 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 33
12:13:44.964 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:home:node14:battery-level to 33 [DecimalType]
Thanks. Not quite what I was hoping for - I read in the spec that the value is meant to be 0 for off, and ff for off, so I was hoping for the same notification event, but with different value…
It will need a small translation somehow but I should provide an update later tonight…
@chris
I’ve set the polling to 1800, for my Fibaro Wall Plug FGWP101. I also set parameters in the FGWP101 to report immediate when power changes with 10%.
What I get in the logs is the following:
2016-09-20 21:19:49.977 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-20 21:19:49.979 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 00 05 07 60 0D 00 00 20 01 FF 47
2016-09-20 21:19:49.981 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 05 07 60 0D 00 00 20 01 FF 47
2016-09-20 21:19:49.983 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 07 60 0D 00 00 20 01 FF
2016-09-20 21:19:49.984 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
2016-09-20 21:19:49.984 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2016-09-20 21:19:49.985 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@3f1538 already registered
2016-09-20 21:19:49.986 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class MULTI_INSTANCE
2016-09-20 21:19:49.988 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 5: Received MULTI_INSTANCE command V0
2016-09-20 21:19:49.990 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 5: Requested Command Class = BASIC (0x20)
2016-09-20 21:19:49.992 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 5: Endpoint 0 not found. Cannot set command classes.
Am I missing something or is this something that will be implemented in the future?
Regards, S
@chris here’s the latest logs (for a press/release)…it’s throwing an error in there:
08:56:12.444 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
08:56:12.455 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
08:56:12.460 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
08:56:12.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 01 00 00 6D
08:56:12.470 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 0A 71 05 00 00 00 FF 08 01 00 00
08:56:12.472 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DETAILS)
08:56:12.473 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
08:56:12.475 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V3
08:56:12.476 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process NOTIFICATION_REPORT V3
08:56:12.478 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 0 = 0, event=1, status=255
08:56:12.479 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = POWER_MANAGEMENT (0)
08:56:12.480 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
08:56:12.482 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
08:56:12.483 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.ClassCastException: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$Alarm cannot be cast to java.lang.Integer
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent.getValue(ZWaveAlarmCommandClass.java:587)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent.getValue(ZWaveAlarmCommandClass.java:1)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.ZWaveIncomingEvent(ZWaveThingHandler.java:926)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:546)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass.processNotificationReport(ZWaveAlarmCommandClass.java:196)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass.handleApplicationCommandRequest(ZWaveAlarmCommandClass.java:123)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:119)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:247)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:213)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:207)[200:org.openhab.binding.zwave:2.0.0.201609212035]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1303)[200:org.openhab.binding.zwave:2.0.0.201609212035]
08:56:12.900 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:12.905 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 453 to 454
08:56:12.917 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
08:56:12.921 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:12.924 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:12.927 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 03 80 03 21
08:56:12.929 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DETAILS)
08:56:12.930 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BATTERY
08:56:12.932 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Received Battery Request
08:56:12.933 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Battery report value = 33
08:56:12.934 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
08:56:12.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
08:56:12.937 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 33
08:56:12.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:home:node14:battery-level to 33 [DecimalType]
08:56:12.943 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
08:56:13.495 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 454 to 455
08:56:13.500 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
08:56:13.510 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
08:56:13.515 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
08:56:13.520 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 0E 0A 71 05 00 00 00 FF 08 00 00 00 6C
08:56:13.525 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 0A 71 05 00 00 00 FF 08 00 00 00
08:56:13.526 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DETAILS)
08:56:13.528 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
08:56:13.529 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V3
08:56:13.530 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process NOTIFICATION_REPORT V3
08:56:13.531 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 0 = 0, event=0, status=255
08:56:13.533 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = POWER_MANAGEMENT (0)
08:56:13.534 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
08:56:13.535 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
08:56:13.537 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
08:56:13.957 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:13.962 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_home_serial_sof changed from 455 to 456
08:56:13.967 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
08:56:13.970 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:13.972 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 0E 03 80 03 21 5D
08:56:13.975 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0E 03 80 03 21
08:56:13.976 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:DETAILS)
08:56:13.977 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BATTERY
08:56:13.979 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Received Battery Request
08:56:13.980 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 14: Battery report value = 33
08:56:13.981 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
08:56:13.982 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
08:56:13.983 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 33
08:56:13.985 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:home:node14:battery-level to 33 [DecimalType]
08:56:13.988 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
This looks like the same issue as raised earlier today and I already know the problem so it will be fixed tonight.
