Is there a workaround for Eclipse Smarthome Designer throwing an error with Openhab2 on every mail entry in a rule?
The error is
The method sendMail(String, String, String) is undefined
The email command works OK, but the errors make it a challenge to spot any other code errors. I’ve updated to a Snapshot build which works better with new rules, but the false errors remain. Is there a way of defining the sendMail command manually?
I have created a lambha sendMail function.
WIth this workarround this fake error only appears once and always at the beginning so it is easy to “filter” it from real errors.
val Functions$Function3<String,String,String ,String> sendMail_lambha=
[email, subject,body
sendMail(email,subject,body)
rule "Test"
System started
sendMail_lambha.apply ("test@test","test","testbody")
Thanks very much, I ended up doing something slightly different inspired by your code.
I created 2 items
String MailSubject
String MailContent
and a single rule in its own rules file
rule "send Email"
when Item MailContent changed then if (MailContent.state !=NULL && MailSubject !=NULL) {
val Subject = MailSubject.state.toString
val Content = MailContent.state.toString
sendMail("myEmailAddress", Subject, Content) }
I send mail by postUpdate to “MailSubject” and “MailContent” The only file showing bogus errors is the one containing the single email send rule
This is not thread safe.
If it is used across different rules, the MailSubject might be changed, e.g. wrong Subject for the MailContent or if MailContent is change at once by different rules you might loose a whole message
