The MUSH-MACHINE: Rule triggering on mqtt values, storing and displaying it
co2_itemsfrontenderrco2_sitemap
Why can´t I show the PPM value properly in the frontend?
Remove the label parameter in the sitemap.
It is already defined in the item
Yes and no!
Yes: i removed the label in the sitemap as you´re right - not needed
No: That wasn´t the problem: I did not realize that the value PPM hast 2 digits. corrected that and it worked
co2_items
Then I created another item for the Sonoff TH16 switch (the one that will later switch the fan) to blow out the Co2.
See: ventil_items
Worked right away : proud!!
See the working sitemap and the frontend
co2_sitemapfrontend
Still not clear:
  • I have to refresh the page to renew the values
  • I would like to visualize the values in a graph and don´t know how
  • Can i use the rule that you created months ago to switch the fan on at a level of 2000ppm and switch it on at a falling level of 1500 ppm and below?
good night..
var Timer timer
rule “Too much CO2”
Item_co2 received update
if (Item_CO2_.value > 1500) {
if (timer === null) {
Item_Ventil.sendCommand(ON) //turn on the vent
timer = createTimer(now.plusMinutes(10), [ | //start and create the timer
Item_Ventil.sendCommand(OFF) //end of timer action
timer = null //reset the timer
Please use the code fences
Hi Vincent,
I created the co2.rules in the rules directory. The item ventil (see above) ist steering the sonoff relais, which is working via mqtt. I could test it positiv via a switch in my sitemap
co2_rule
rule “Too much CO2”
    if (Item_co2_.state > 1500) {
Yes of course .. fences.. are there just beeing ruined by the editor.
sorry!
ps: in a world without borders and fences who needs gates and windows ;-)))
how can i test if Item_Ventil.sendCommand(ON) //turn on the vent really works. I doubt a bit that “ON” will passed on correctly to the mqtt string. see items:
ventil_items
I can’t read that
Please copy and paste the text
Switch ventil “Entlüftung” (LR,gLight) { mqtt=“>[ohbroker:cmnd/ventilator/POWER:command:*:default], <[ohbroker:cmnd/ventilator/POWER:state:default]” }
if you click on the jpg it would show you the text larger.
What about:
Switch ventil “Entlüftung” (LR,gLight) { mqtt=">[ohbroker:cmnd/ventilator/POWER:command:*:default], <[ohbroker:cmnd/ventilator/POWER:state:default]" }
:grinning::sunglasses:
Aehm .. yes the switch is working perfectly right, i just doubt that the quote.. Item_Ventil.sendCommand(ON) in the ruleset will work.. and how can I test that?
:flushed: ok understood:
Codefences
Aehm … yes the switch is working perfectly right, i just doubt that the quote…
in the ruleset will work… and how can I test that?
sorry for my “slow wire” …:worried:
