Hey David,
Thanks for the new versions. Skipped 8 and went straight to 9.
We have some control! I added Color Zone 1, which is what my bulbs are linked too. Color Zone 1 and iBox were able to turn off and on very consistently. Color picker did not seem to work whatsoever for either zones. Keep in mind these are RGBWW bulbs, not sure if that means these are technically separate zones than Color 1, or if there are specific RGBWW zones.
On both the iBox and the Zone 1 Color, they reached max brightness around ~38%. From about 40-95%, there is no change. After about 95 and up to 100%, it was almost like they were in NightMode, very low brightness. Speaking of NightMode, could not disable NightMode once it was enabled on either Zone 1 Color or the iBox. The only way I found to disable NightMode, is to turn first toggle NightMode off and then toggle the main on/off via the switcher.
I am attaching logs from some of my testing.
This is serious progress!!! Thanks again David.
John
alpha9.txt.pdf (80.3 KB)
EDIT 1 - I realized just a moment ago, that after I upgraded my OH2 pkg earlier, I forgot to reset DEBUG. So here is new log with debug enabled.
Summary (and some more info post EDIT) - On both Color Zone 1 (RGBWW bulbs) and iBox, color picker does nothing, but Brightness slider in color picker works.
On both, brightness slider works from 0 to ~38%. From ~38-96%, no effect. From 97-100%, dims bulb to same as 0%, practically to NightMode.
Brightness On/Off works pretty darn consistent. It does toggle it back to 100% brightness, but this 100% is like the 35% max bright. Going to a different %, then back to 100, results in same 0% brightness.
NightMode will not disable via switch. Must toggle to Off, then toggle Brightness Off, then On to reset.
Animation seems to work. However, âIdleâ does not stop animation (not sure if that is intended result or not)
alpha9-debugset.txt.pdf (30.6 KB)
