# apt update
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Get:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease [12.8 kB]
Err:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 075721F6A224060A
Reading package lists... Done
W: GPG error: https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 075721F6A224060A
E: The repository 'https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
It’s generic instructions for Linux and normally noone would ever apply this on Raspi OS as there’s the openHABian image available and recommended to use on Raspberries.
The following signatures were invalid: EXPKEYSIG 075721F6A224060A openHAB Bintray Repositories <owner@openhab.org>
I followed the instructions on the download page and now everything is ok.
The step you mentioned ( Added key with apt-key as well: ) does not help you as that seems to install the key in /etc/apt/trusted.gpg while your openhab.list used the key that is stored in /usr/share/keyrings/openhab.pgp.
I think something went wrong or you did not follow the exact steps to install the key under
/usr/share/keyrings/openhab.pgp - as it works here.
In the meantime I found the solution. I read in one of the blog that the “signed by” clause in /apt/sources.list.d should have the .pgp extension in stead of .gpg.
Clearly this was wrong: I changed it back to .gpg and now all fine
# cat openhab.list
deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main
# apt update
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
Get:6 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [374 kB]
Get:7 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [383 kB]
Get:8 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main arm64 Packages [5,447 B]
Get:9 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf Packages [5,447 B]
Fetched 847 kB in 3s (314 kB/s)
Building dependency tree... Done
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
It obviously doesn’t make sense to refer to a pgp file when it’s gpg.
That’s also not in the install instructions you quoted.
So you should at least have told us that you changed it.
All of this fiddling (not to mention asking others for support and their time to provide it) is avoided by using openHABian. It’s made to relieve from exactly all of this unnecessary work, so everybody please deploy it to that purpose rather than use manual install if you’re on a platform that it supports.
