the following rule is running fine, altough I always receive this message in openhab.log:
The value of the local variable adddelay is not used
the rule for that:
rule "Systemdevice is offline"
Member of gHeartbeat changed from ON to OFF
var Timer adddelay = null
adddelay = createTimer(now.plusMinutes(2), [ |
if (gHeartbeat.state == OFF) {
logInfo("Systemdevice is offline", "check device: " + triggeringItem.name)
I found lots of rule example exactly doing the same Timer delays, but why do I always get that messages?
Because you are creating a variable named adddelay.
You then assign a new Timer that you created to adddelay.
Then the Rule exits and adddelay goes away without ever being used.
If you want to be able to look at the created Timer the next time the Rule runs or some other Rule runs, move the var Timer adddelay = null above all the Rules so it is a global.
If you don’t, get rid of it because you aren’t doing anything with it.
I have a rule where I am seeing the same thing, but not on every reload.
BTW I never see that message when the rule is reloaded after an edit.
In my alarm decode rules I have
val String PATTERN = "MM/dd HH:mm "
rule "Front Door"
Item zone1 changed from CLOSED to OPEN
var String ts = now.toString(PATTERN)
var String home = Home_Away.state
if (home == NULL || home != "AWAY") home = "HOME"
postUpdate(zone1_Last, ts + "Front Door Opened")
if (home != "HOME" ||
(home == "HOME" && (now.getHourOfDay > 22 || now.getHourOfDay < 6))) {
sendBroadcastNotification("Front Door Opened")
Every rule have the same lines until the postUpdate, so both home and ts have always been used
Sometimes I have seen the message repeated a few time, but mostly it reports one or both ts and home once
One other form I have is like this for the windows: (and one non-entry door)
rule "Side Door"
Item zone5 changed from CLOSED to OPEN
postUpdate(zone5_Last, ts + "Side Door Open")
Also is there a way to invoke the rule parser without doing a restart?
I had an incident of this transient error just last night, , value of local variable id not used. “id” is a declaration within a rule, set to this or that, and used in a postUpdate, not dissimilar to that last example.
Occurred at system boot time, re-saving the .rules file parsed just fine.
OH 2.4.0 release.
May be significant that we have two-character names in common, but I doubt that.
In my case, i had two similar rules with a local id (string) variable, which should be fine of course, but later changed one to different name as a precaution.
Very strange… I split the file by putting all the ones that did about the same thing together.
No warnings
Here are both files,I even put them back together and the error came back!
rule "Front Door"
var String timestamp = now.toString(PATTERN)
postUpdate(zone1_Last, timestamp + "Front Door Opened")
rule "Laundry Door"
Item zone2 changed from CLOSED to OPEN
postUpdate(zone2_Last, timestamp + "Laundry Door Opened")
sendBroadcastNotification("Laundry Door Opened")
rule "Back Door"
Item zone8 changed from CLOSED to OPEN
postUpdate(zone8_Last, timestamp + "Back Door Opened")
sendBroadcastNotification("Back Door Opened")
and
rule "FR Motion"
Item zone3 changed from CLOSED to OPEN
postUpdate(zone3_Last, timestamp + "FR Motion")
rule "DR Motion"
Item zone4 changed from CLOSED to OPEN
postUpdate(zone4_Last, timestamp + "DR Motion")
rule "Side Door"
postUpdate(zone5_Last, timestamp + "Side Door Open")
rule "BR Windows"
Item zone6 changed from CLOSED to OPEN
postUpdate(zone6_Last, timestamp + "BR Windows Open")
rule "MBR Windows"
Item zone7 changed from CLOSED to OPEN
postUpdate(zone7_Last, timestamp + "MBR Windows Open")
Try giving each var a unique name e.g. timestamp1 , timestamp2. Obviously this shouldn’t matter but it might give a lead for recreating the problem for a bug report.
