Hi, I just installed OpenHAB to figure out if I want to migrate from Homeseer.
Regarding the Yamaha Binding, is the control that I get (channels) the only ones implemented?
I wrote a plugin for Homeseer where I scan the instructions for the amplifier for all the commands, make that into an XML and then the plugin uses the XML to create all controls from the instruction book automatically.
I have a glass door in front of my center speaker and I have a switch connected to that glass door. I defenitely want the switch to control the configuration in the amplifier to turn off the speaker when the door is closed. But it does not seem to be possible with the plugin as it is today in OpenHAB, is it?
